Kiox (NOT 300….) power output to phone
kipperkendall
45
28
England
Firstly for those who don’t know, the Kiox has a micro USB power output that you can plug your phone into.
I bought a cable that was advertised as the Bosch Kiox to phone cable that works, but it doesn’t look like the correct micro version. Anyone know what the correct output is? Anyone bought the 100% correct cable?
I’ve got an iPhone
RipGroove
375
185
Glos/UK
On the bottom of the unit, under a rubber cover
I'm not seeing a rubber cover?
audistwo
32
65
Angus
Hattori-Hanzo
283
308
Sorry, yeah I was referring to the LED controller not the display for the Kiox 300 smart system (y)
Though as I understood it is only for charging the controller and not to power other devices?
Kwaka
Cheddar, Somerset, UK
I contacted Bosch support and they said you cant power a phone from either the led controller or the kiox 300. Yes there is a port in the led controller but I couldn’t get it to work with the iPhone.
kipperkendall
45
28
England
Strangely, mine works a test and charges my iPhone perfectly! I’m using a micro B cable but just ordered a micro A that will fit better. But it definitely works
kipperkendall
45
28
England
To help here’s some images of my Kiox 300 showing the power out port. The correct connector is a Micro A USB but a Micro B will work as it’s the same pin layout. This is on the non flow system
kipperkendall
45
28
England
Ahhh, you are correct 😟
Got confused on the Bosch site. I bought the retrofit Kiox which appears on the same page as the 300. So assumed that was the unit! It looks like the 300 is for the Smart system.
Sorry for confusion.
530K
