Bosch Gen 4 Chainring Nut printed Torque of 25 to 30 NM is likely wrong
Okay so Europe and US Bosch disagree.
Indeed. Or verbal statements differ from written statements as the latter could engage responsibility in case a strong torque would create damages.
you could try to get a written statement of the US support, as I managed to get in EU ;)
I have tried several times to obtain a written statement but so far Bosch is not willing to put the new spec in writing, instead they are going around to local bike shop/bosch dealers and verbally telling them the new spec and having them update all the bikes on the floor to the new spec. This is not an ideal situation for consumers. I have tried my best to provide all the facts I know to this user community as I don't want anyone to get their ride or vacation ruined over a dropped off chain ring as we almost did.
I did a quick online search both of suppliers and various "ebike" companies who tend to provide more guidance alongside products. There was a bsolutely no sign of any change to the original torque settings. As far as I know Bosch do not manufacture fasteners but outsource that to the relevant suppliers. Those suppliers use engineering tables to determine a torque setting for fasteners they manufacture ( material, thread length, thread pitch etc). It seems ludicrous to me that anyone could propose increasing torque for a fastern assessed in that way from 25/30 nm to up 45nm....a 50% increase!!
FWIW - TQ 50 NM, Brose 50 NM and Shimano 35 to 45 nm is the lockring torque spec for essentially the same part on a very comparable ebike motor ie. use scenario- so it is likely the Bosch outsource manufacture just got it wrong when they thought 25 to 30 nm would work given the amount of lockring issues that have been reported for Bosch bikes vs. almost none I have heard of for Shimano or Brose.
Unfortunately bike manufactures (unlike airplanes and cars) don't seem to take this stuff seriously enough to recall/throwaway parts so they have a habit of just keeping the old stuff in inventory even though it may have a improper label. TQ is doing this as well apparently - from Fuel EX thread " Torque should be 50Nm. Some older lockrings were stamped with 30Nm, but they can come loose. Mine did, 50Nm solved it."
Good luck with however you decide to resolve the aforementioned, I sleep well at 40 nm and have since never lost a lockring on either bike.
V
As far as I can see Brose etc specify the same 25-30nm.
Interesting that the torque for the lockring that attaches the chainring to the crank on a standard ( non E) bike is 40nm. I wonder if that is where the confusion is.
See attached
Confirmed with local Specilized dealer it is 50 NM just like Shimano is 35 to 45 nm.
Good idea just hit unwatch on the thread, I just did so I am out going forward. Good luck guys.
I have always used 30nm and never had any problems. I find it unbelieveable that an ally nut with so few threads would need or even survive 50nm!! I also wonder how many have a torque wrench for anti clockwise threads!
I believe the issue of chainrings coming loose for folk starts with the original installation being poor, and is followed by people then re using the lock nut after it has come loose...only for it to come loose a gain even if correctly installed this time. The reason I would suggest is that the minimal amount of thread on the locknut has been damaged. It is also the case that the initial installation may have involved too much torque (power tool used??).
With a bolt/machine screw, exceeding the engineering book torque risks shearing the bolt at its weakest point......where the thread initiates a fter the head of the bolt.
With a nut, it is different. The correct torque will apply the maximum friction between the threads of the nut and the threads of what it is fixed to. The correct torque is only marginally below the shear point and will involve some "spreading of the thread shoulders. So re using that nut may or may not be possible depending on how much spread occured in the threads.
Either way for the sake of c £10 the safest course of action is to always use a fresh lock nut.
Yes, blue loctite will also work but it depends how damaged the nut is......and it will make it more difficult to remove if needed.
I have four torque wrenches they all work clock or anti clock
Hi!
So, to keep it short; count me. Unfortunately. After 600+ km; Bosch Performance Line CX Gen 4 on Cube; I was just pedaling to store; 2km from home; it got completely loose, so got lucky there as it did not happen on longer ride away from home.
Tried to tighten it with hand; had to redo 2x to home. Now; I am getting tools and something like loctite to fasten this thing. It is pretty annoying actually. Just trying to image if this would happen 30 km from home.
Hi everyone,
this is the fourth time the lockring has been coming loose.
In order I tried:
Used lockring new o-ring with grease 30Nm
Used lockring new o-ring with Loctite 30Nm
New lockring new o-ring with grease 30Nm
Steel lockring (selfmade on leathe) new o-ring with grease 30Nm
I have a torque wrench that works in both directions, so I'm sure about the tightening torques.
I'll try tightening the lockring to 45nm, in the worst case, if it doesn't hold, I'll have to throw the lockring away.
It's a nut on an ebike. Nothing is fit and forget. Just keep an eye on it as over tightening Wil only stretch it.
It also won't need any grease as the O ring will deform too easily instead of just squashing.
Don't use the O ring, you don't need it and I think this is the main reason it comes loose.
I've been running 3 different bikes over 4 years without the O ring never any problems and never come loose.
Hi everyone,
In order I tried:
there is no need for grease on such a short amount of thread...........just make sure the thread is clean. At the end of the day if the lockring keeps coming loose I would guess the chain ring rather than the lockring is the problem.
Guess what the new Bosch lockring that I just bought and installed says on it? 35 nm
Edit:
Lockrings dated 11-2018 said 25-30nm
This lockring dated 10-2023 says 35nm
As before used blue thread locker (Loctite 243) and no O ring but tightened to 35nm instead of 30nm, and again put a telltale on it which previously told me it was coming loose.
I just drilled between castellations and fitted a roll pin - sorted.
Interestingly (or not!) I was looking for a CX gen4 locknut.
Mine has a 25-30Nm printed on it.
I found a Bosch Cargo locknut, which looked the same but had 35Nm printed in it.
Maybe a different nut or made from a different material ? Needs a lot more torque to shift those boxes.
I suspect the difference is the material used....different grades of ally. Given the very small number of threads I would not exceed 25nm and I would avoid re-use .
Yes agreed but does anyone know if the Cargo nut is the same thread.
If so it maybe an upgrade option as the queries in this thread!
the thread pitch will be determined by the motor spindle.
Just an update. The supplier of the Cargo locknut says it does fit…..same thread. I have ordered on as I need on anyway but it may solve the loosening issue in the OP.
I must say I have had 3 Bosch gen 4 motors in separate bikes and never had a problem with the 25-30Nm recommendation.
Bosch locknuts now have 35Nm printed on them. See my earlier post.
Thanks Irie. I think I missed your post. Are the new ones made of a different material do you think?
There is a dealer stating there are 3 versions:
BOSCH E-Bike 4. Generation
EB112000JH (prev. 1270014085 + 1270016119)
Current versions is showing 35Nm
However, my 2022 Cube has this and had not probs. Also there is no o-ring fitted.
    676K
