Canyon Shawn
Looks.What improves with a better headset?
I could use a little more drop than the Bontrager 150mm in my M – anyone know off-hand how much more (than 261mm) can go into the frame?
After a quick-&-dirty measurement on the outside of the seat tube, it does not look like there would be a lot more space available …
Thx …
From the Fuel EXe FAQ.
Fuel Exe FAQ
www.trekbikes.com
How much dropper post insertion does the frame have? (alloy & carbon)
S – 190mm, M – 225mm, L – 250mm, XL – 280mm. The minimum amount of insertion is 80mm.
As per social_rider’s post above, it’s 225mm per Trek’s website.Does anyone happen to know the max seatpost insertion length for a medium carbon 9.7? Thanks!
Thanks!As per social_rider’s post above, it’s 225mm per Trek’s website.
agree - looks like the air can will foul the frame at the bottom.Hi All, Following the release of the new Rock Shox Vivid, this is a pic of a roughly scaled cutout (205mm eye to eye) against my frame. There will be some possible interference with the bottle mount / tool as the remote reservoir rotates forward on the rocker.... but it looks like there will be a clearance problem between the massive inverted air can and the seat tube. The do make the shock in the applicable size and configuration for the bike, and they sell specific tune shocks for the Slash and Rail, any word if it will fit the Fuel EXe? I think the Fuel Ex won't be an issue either, as the lower mount seems further away from the seat tube? Anyone else looking into this or have access to a Vivid for sizing? I've asked the local Trek Importers for feedback too, let's see if they have any feedback. Would be a shame if one can't fit it, looks like a great shock option. Attached pics of cutout Viviid and stock setup...
View attachment 123099 View attachment 123100
Do you perhaps know if the Wolftooth IS41 top fits snugly on the EXe?Wolftooth sells an IS41 top, I've been very happy with their headsets on other bikes.
Meanwhile, a fine weekend....
Can't say I do- my other bike has their IS42 and the quality is great- but it's not IS41.Do you perhaps know if the Wolftooth IS41 top fits snugly on the EXe?
The stock ring is 32T. (unless something get swapped)Should I get a small chainring? With the stock 34T chainring I need assist level 2 on steep sections and level 3 if the trail is steep and long. That works but I end up going kinda fast if I keep my rpm's up. My manual bike has a 28 tooth chainring and it is perfect. Should I just get used to the 34T or get a Wolf Tooth 30T? I wouldn't miss the lower high gear.
By the way, there is a side benefit of a smaller chainring. There would be less noise from cross chaining on the 51T cassette because I would use higher gears more often.
Yeh or Nay?
Thanks for the info!The stock ring is 32T. (unless something get swapped)
30T would keep you out of that maxed out gear.
in 30T-10T you'll be over the speed cutoff by 75 rpms. yes, the EXe pedals well over the cutoff, but for overall assisted trail riding it should be fine. View attachment 123154
I put the same tire on my 9.8XT As well and I love it after the first ride. It also took me a while to get it on. Could not do it in the stand so I put it on the floor and stepped on it to keep the tire on the rim While getting the rest in.It’s a 2.4, not easiest to seat. A little tough to get on the rim, I usually partially inflate and then spray some soapy water around the tire and rim. And it seats.
This could also be caused by a software update. My bike was very hesitant in boost and would never give me the expected power based on the settings. It also was cutting out when pedaled at a steady pace (not accelerating). A software update back in April improved that a lot.I got my bike back yesterday and rode it home for like 4 miles. I swear it has more power in High mode, with the new motor. That’s the only mode I rode it in because it’s up hill all the way home. And when I got home, I realized that the motor settings had reverted back to default. So, I wasn’t even at full power. I’ll take it for a 30 mile single track ride this weekend and see how it goes. The only thing I don’t like about getting a new motor is the odometer and all your settings revert back to default.
Yeah, that could be. Although, just before they changed motors, the original motor was up to date. I had no complaints with the first motor. But, after putting about 60 miles on the new one, it definitely has more power. Other than that, it feels just like the first motor.This could also be caused by a software update. My bike was very hesitant in boost and would never give me the expected power based on the settings. It also was cutting out when pedaled at a steady pace (not accelerating). A software update back in April improved that a lot.
Quick update:From Fidlock: thank you for your enquiry. At the moment we do not sell the force connector. Therefore it is not available for purchase. Look for it in our webshop towards the end of the year.
I got my fidlock adapter here:Quick update:
TQ Range Extender Fidlock
Bike24.de has listed the mount adapter, but unfortunately not available:
Yep,it isIf you go to the Trek app and adjust the lowest power settings to full max, is that essentially the same as adjusting the highest power settings to full max?
Thank you for sharing this topic with pictures.Sram UDH stop on the seat stay of the carbon frames - this part is very fragile. The UDH says 25nm torque, but I would not suggest that much. Enough where it doesn’t move and maybe hold the udh with your hand while torquing hand tight. The reason I say that is because I gouged my EXe 9.7 this way.
5DEVWhat would it be like to go from 165mm cranks to 155mm cranks? Apart from the obvious, less pedal strikes. And, what cranks are available for our bikes? Thanks!
