Giff
Has anyone upgraded to the newSRAM T type
group set ?
Any opinions / comments?
group set ?
I’ve been running the XX one now for about 6 weeks and overall am really impressed.
I previously had AXS XX1 on the bike.
Now I’ve found the correct spot, I love the new ‘pod’ controller, the setup is sooo easy, and the shifting is flawless every time. I generally never shift under load anyway, so I don’t notice a difference there.
Was it worth the price to upgrade from my previous AXS? Probably not.
I did manage to get about £500 back selling it on eBay, but the upgrade was over £1300!
The stock one is T-Type compatible, as the S-Works build comes with T-Type.
Yes, T-Type can still make a noise, it’s not silent but it is nevertheless designed to shift under load.I’m still trying to get my head around the full power shifting that people report. Even under low–medium power, it can make loud cracking sounds and I would never ever consider shifting it under full load. Even on a non-ebike. I can’t see how it would survive a single ride with me shifting while stomping the pedals. I rode the last AXS before AXS T-Type and the latest Shimano groupset and have to avoid shifting those under load too. The few times I tried it, I destroyed a cassette and snapped a chain.
Thanks for the feedback. So I just need to ignore the noise and have some faith?Yes, T-Type can still make a noise, it’s not silent but it is nevertheless designed to shift under load.
I have a normal AXS setup on my other EMTB and you do need to back off a little if you want a smooth shift, or don’t want to destroy stuff.
Th
been on for 8 weeks now not mist a beat awesome bit of kit .shame it’s crazy moneyHas anyone upgraded to the newSRAM T type
group set ?
I switched from AXS to the new X0 T-Type drivetrain (cassette, derailleur, chain and crank chainring (SRAM direct mount T type for Shimano crank) on my SC Bullit. The shifts are more accurate, much better under load (especially climbing), quieter drivetrain as well. My son did the same on his Nomad (non-ebike) and noticed a bit less drag, likely due to larger derailleur pulleys..Has anyone upgraded to the newSRAM T type
group set ?
Oops, forgot this SRAM link that may help if you're not sure the shift is quite right or sounds off:I switched from AXS to the new X0 T-Type drivetrain (cassette, derailleur, chain and crank chainring (SRAM direct mount T type for Shimano crank) on my SC Bullit. The shifts are more accurate, much better under load (especially climbing), quieter drivetrain as well. My son did the same on his Nomad (non-ebike) and noticed a bit less drag, likely due to larger derailleur pulleys..
(maybe benefits ebike range?)
I live the overall performance and haven’t busted a chain like my earlier drivetrain!
So, I used the MicroAdjust to set the derailleur where I thought it needed to be. This turned out to be position 14 of 14.Oops, forgot this SRAM link that may help if you're not sure the shift is quite right or sounds off:
I had the bike in at the bike shop for something else, so I set the MicroAdjust back to the middle position and had them re-adjust it. They also set it at position 14. It's shifting much better set in that position.
I've found that after I remove/reinstall the rear wheel, the shifting can be quite off. I can only guess that the amount of axle torque is enough to affect the shifting. Maybe there's enough combined variation in the rear end with the derailleur + axle torque + chain stay pivot (Trek Rail), that the derailleur is not always where it needs to be, or ends up easily moved enough to affect shifting. Maybe my derailleur is slightly off from the factory?
At least it's shifting well now, but I'd rather not have to be at the absolute limit of adjustment to have it shift OK.
Curious, I wonder if you can have the crank installation setup checked and have chain-line verified correct?So, I used the MicroAdjust to set the derailleur where I thought it needed to be. This turned out to be position 14 of 14.
It's a T-Type chainring direct mounted to the Bosch motor, so I hope it's correct.Curious, I wonder if you can have the crank installation setup checked and have chain-line verified correct?
T-type is unique using a 55mm chain line whereas prior kits were 52-ish, which is why the front crankset is changed or (as with EP8 /EP801 motors and Shimano crankset) the crank gear is changed. Since that could affect alignment it might be good to verify.
Thanks for the suggestion. It all seems to be correct. No freeplay or anything that looks off.Just a guess, but perhaps your freehub is not fully seated or your axle end caps are not fully seated.
This should be it…It's a T-Type chainring direct mounted to the Bosch motor, so I hope it's correct.
My GX groupset actually came with this chainring. Not sure why.![]()
EAGLE TRANSMISSION E-MTB KETTENBLATT FÜR BOSCH - CR-TTYP-BO-A1 - SRAM
EAGLE TRANSMISSION E-MTB KETTENBLATT FÜR BOSCH, CR-TTYP-BO-A1, SRAM. Die SRAM-Antriebsingenieure haben dieses Kettenblatt speziell für Bosch-Motorsysteme entwickelt, um die hohen Drehmomente und den hohen Verschleiß zu ...www.sram.com
…lol, help if I included link!
Cool, that’s the high-end one so you shouldn't have chain line issues due to that. As long as your hub’s in shape and your axles centering right it should shift smoothly, not sure why derailleur trim maxes outMy GX groupset actually came with this chainring. Not sure why.
XX EAGLE TRANSMISSION DIRECT-MOUNT E-MTB KETTENBLATT FÜR BOSCH - CR-XX-BO-D1 - SRAM
XX EAGLE TRANSMISSION DIRECT-MOUNT E-MTB KETTENBLATT FÜR BOSCH, CR-XX-BO-D1, SRAM. Dieses Kettenblatt wurde speziell für die Verwendung mit Bosch-Motorsystemen entwickelt und ist das leichteste und fortschrittlichste e-spezifische Ke...www.sram.com
The only other thing that comes to mind is that the splines on the cassette are not fully seated on the freehub, so it offset outwards a bit. A setting of 14 does seem like a lot of adjustment needed to get proper alignment, but if it's working flawlessly, maybe it just "is what it is".
My Transmission on my current bike is set at 8 - so pretty much in the middle.
I have the original AXS on my Stumpy, which has 31 adjustment settings. It's set at 16 - again, in the middle... however I sometimes use that bike on a Wahoo Kickr. When on there, I need to set it to 31, as the cassette must have some sort of offset.
