do you know if they changed the watt limit on the motor also? That is probably the main limiter with the rise anyway and the smaller batteryshop changed the firmware to standard EP8 85nm upon my request.
I don't know the details, but I assume changing to EP8 firmware includes all the values that would normally be applied to the EP8 motor. Shimano warns that the battery will drain more quickly but that's to be expected. Apparently Shimano has facilitated the firmware change on quite a few RS motors.do you know if they changed the watt limit on the motor also?
R u me? Cause this is me as wellHi all I'm looking at a rise h15 for its lightweight and great price but I'm wondering can you turn the ep8rs up to standard ep8 power ? I'm coming from a full power giant alot heavier but I only do 20mile max rides once a week with friends so range isn't a problem just be nice to have full power ?
I have an H15 and set up to be Profile 1 in RS mode, Profile 2 Full power unlocked. Bosch def a bit more power as I have a Rail 7 as well. but the ep8 is known to feel less powerful than the Bosch cx4. I like the H15 due to extender capability as I have 2 so I have 1044WH available vs 625WH on the Rail.R u me? Cause this is me as well![]()
Interesting. I've always wondered how different the RS firmware is - the 'pitch' from Orbea was that they'd not just limited the maximum power (which you can do yourself in the app), but also tweaked how that power was delivered to make it more 'natural' - what I *think* that means is that it delivers most power at high cadences (the same as you'd use on a normal bike). But I've not ridden other Shimano motors to compare.Reviving an old thread here
So, long story short … I’ve just had my EP8RS motor replaced under warranty. I’ve noticed via the e-tube app that the new motor has been sent out as full power, 85Nm
Now I don’t need that much power, 60Nm is more than enough, rarely ride in Boost anyway, Eco or Trail mainly
My concern is that even though I’ve dailed down the settings in the app, so only boost will achieve 60Nm, will the full power motor still kick out more watts than the de tuned RS motor and therefore have a detrimental affect on my 360Wh battery ?
My lbs have advised that they can send the motor back to Maddison to have it detuned to RS spec, but I’ll be without the bike (again) for another few weeks and I’ve just been without it since the beginning of May so am keen to jump on the saddle and turn those cranks
But on the RS you can't leave it in a low gear and get masses of power in the way you can on a Bosch motor on the Wild for example (or on most other e-bikes)
It will get face a lot bigger forces from drops and jumps to be honest. Have you ever heard any Rise to break because on torque from motor?One thing that's not mentioned at all in this thread is that the rise frame has been developed around the 60nm output. Not 85. The frame is lighter and not as strong as a full fat bike.
So.... full fatting the rise could potentially lead to frame failure.
Rated output of those cells are lot higher than our motors can pull out. So I would like really to see some proofs. For example in this forum I see zero threads about battery getting ruined.Running the EP8RS at anything above 60nm will overheat and degrade your battery. I've even seen running it at 60nm for extended periods will ruin the batteries in these. It's not as bad in the 540wh, but will toast a 360wh in no time
It's not a motorcycle. The torque numbers we're talking about are within the range of a fit human. Track cyclists can put out 200+ NM. The frame isn't going to break from the motor torque, else they would break from rider input as well.One thing that's not mentioned at all in this thread is that the rise frame has been developed around the 60nm output. Not 85. The frame is lighter and not as strong as a full fat bike.
Download the app, Connect the bike and switch from ep8 rs to ep8Hi all, new to the forum.
My daughter has a Rise H30, myself a Decoy 29. I had the opportunity to ride the Rise for the first time last week and was disappointed in the way the assist comes into play at lower cadence. Definitely not as much fun to ride the Rise on the twisty trails we have. Where the Decoy will smoothly pull a higher gear from corner to corner or up a short punchy climb the Rise will reduce the assist as your cadence falls, necessitating more shifting. Since I rarely use boost on my bike more overall power isn't necessarily the goal, but more grunt would be more fun on the Orbea.
Just back from the dealer to have them clear the service icon on the display on the Rise, inquired with the mechanic as to the likelihood of having Shimano OK changing to EP8 firmware. He's on board and sent an email to Shimano but is not optimistic.
If that doesn't fly I hope to make the change with STunlocker, and would appreciate any advice from those who have gone that route.
Cheers, Andy
Using STunlocker voids the warranty and there's lots of EP8 failures out there. So only do it if you're willing to spend $1k on a new motor if it fails.Hi all, new to the forum.
Cheers, Andy
What kind of failures have been seen? Probably going to risk it, if necessary, as it isn't much fun to ride the way it is. Other option would be to find a Rocky and sell the Rise. It's a nice bike otherwise, and likely have to eat more than $1000 trading.Using STunlocker voids the warranty and there's lots of EP8 failures out there. So only do it if you're willing to spend $1k on a new motor if it fails.
Cheers, Andy
There's a very common error that results in total motor failure and replacement. I think it's like E010 or something like that. Besides that, I'm no mechanic so can't give you specifics, just what I've seen on my research. There's an EMTB Motor Repair page on Facebook and the dude could tell you more.What kind of failures have been seen? Probably going to risk it, if necessary, as it isn't much fun to ride the way it is. Other option would be to find a Rocky and sell the Rise. It's a nice bike otherwise, and likely have to eat more than $1000 trading.
Cheers.
. It gives such little support. Profile 2 is much better and mandatory for people over 200lbs.If you need to send it to a Shimano Service Centre after using STUnlocker, you just have to undo the changes.Using STunlocker voids the warranty and there's lots of EP8 failures out there. So only do it if you're willing to spend $1k on a new motor if it fails.
I was told they can tell if you've ever used STunlockerIf you need to send it to a Shimano Service Centre after using STUnlocker, you just have to undo the changes.
It's quite easy and fast to do.
Also if the motor breaks and you can't get back in to flash it, you'd be screwedIf you need to send it to a Shimano Service Centre after using STUnlocker, you just have to undo the changes.
Well I guess we get to differ on this subject.It will get face a lot bigger forces from drops and jumps to be honest. Have you ever heard any Rise to break because on torque from motor?
I enjoy RS power delivery as well but having option to push 85nm(500w) is really great in situations where you ride with friends who have full fats. With Rise im as fast as them and actually also have more battery left. (Rise H).
My modes are eco(RS 35nm), trail (RS 60nm), boost (85nm/500w).
To add the rise has a very low weight limit compared to other ebikes. With kit the limit is like 280lbs while full fats easily handle 300lbs-350lbs. Evidence is right there lol.Well I guess we get to differ on this subject.
The Rise is a proclaimed by Orbea to be a weight weenie optimised everything for lighter weight. That includes the frame. They have enclosed the battery in the frame which leads to weight savings but thats not all of it. They have also optimised the rest of the frame from the weight savings.
Hind-Corners, Its not just the motor output that you need to consider its the total power output. So rider torque+motor torque... By increasing torque you risk taking the bike passed its design limits. By doing that you are entering into the possibility of early failure because the bike hasnt been designed to take those loads.
An average rider doing average miles probably wont take the bike passed its design limits. But if you are a heavy and or more powerful or higher use rider then you may very well go see component or frame failure.
Lets be honest most shimano ep8 fitting bikes with similar battery size are 3-5kg heavier. Most of that weight savings is come from the frame.
There's the engineering old analogy light, strong, cheap, pick 2.
The rise is mid range in pricing and its lighter. So........ its not as strong.
Bigtuna, No I haven't heard of a Rise breaking. But the only Rise owner I personally know is my daughter and she is light and non extreme. I do ride the rise on occasion so the most redonculousness it gets subjected to is me and I don't ride the bike like I stole it as its my daughters bike and not mine. Plus its a low travel trail bike not designed for the kind of tomfoolery I undertake on my enduro and dh bikes.
Wicked piece of kit I have to admit.
It's already maxed out on profile 2, the assist is still weak off the bottom, and I weigh 130 lb. Perhaps bigger, stronger riders don't notice the same issue. Maybe it's so long riding single speeds, but honestly I'd rather ride my analog bike.There's a very common error that results in total motor failure and replacement. I think it's like E010 or something like that. Besides that, I'm no mechanic so can't give you specifics, just what I've seen on my research. There's an EMTB Motor Repair page on Facebook and the dude could tell you more.
I'd also recommend switching to Profile 2. I first took out profile 1 and was pissed. It gives such little support. Profile 2 is much better and mandatory for people over 200lbs.
