Shorter Cranks
The q-factor seems to be 16, so you should measure your current crank arms.
There is also a different Q:16 version with a 5.5mm offset at the mount. You should check that.
The Miranda Cranks are available from Dilglove, as mentioned in the other thread, and come in range of sizes
Not sure if the ones linked in this post are the same and/or correct but only £36 incl. shipping
Ah killswitch, you've joined the battery Revolution. I thought I recognised that name from the old forum days.
No way .. is that .................. Malamute ?
Old forum went dead .
Yes im In the Electric revolution ! and here to stay ..
That's a bloody good guess. Yes it's me mate. Good to see you on the other side.
    Join 43,277
