If anyone would ever have this problem. This is how I solved it.
I bought left taps (ez out) to remove the broken bolt.
I replaced with stronger screws. Tensile strength of 10.9. zinc plated. Because stainless could cause contact corrosion with magnesium case. The screw bits are 5 point torx (ts) with hole.
Which fasteners are you referring to? The motor bracket screws are not torx plus; they are 5pt pentalobe security bit size 25.Just offering a tip for anyone to prevent rounding the bolts off as I've done this myself. The bolts use a torx plus bit to remove not a standard torx bit. They are very similar but the fit of a torx plus is much better.
And now everyone is confusedI replaced mine with stainless Allen bolts. Only because I had them handy and I used a standard torx to remove the original bolts.
Sorry I been on the beerAnd now everyone is confused
What size drill bit did you use for the pilot hole? Did you use the smallest EzE-out? I believe I have the same size eze-out kit. Did you use a drill press and centre the drill bit or a hand drill?If anyone would ever have this problem. This is how I solved it.
I’m not sure yet. Hopefully I don’t do anymore damage when I remove the broken bolts. The holes in the bracket may be out-of-round also (Two broken screws Stihldog? I'd start with the smallest EZE-Out; can always go bigger. What screws are you going to replace them with?
Yes, the grease does look rusty coloured. There was some water ingress along the casing seal so I carefully checked the gears and cpu board. There was no rust pitting on the gears but the very small amount of water has me worried. Basically enough water to get one end of a Q-tip damp. I believe the water may be entering through the casing seal in spots.What's up with the rusty coloured grease on the big gear? Does that indicate water ingress? Seems like quite a long way into the shaft to reach that gear...
Thanks for the shout out for Cycle Chrome, those guys have put a lot of effort into learning about eBike motors, including flying over to the UK to spend a few days training with us. As for your water ingress, I think what you perceive to be water is oil. This is a very light clear oil that looks just like water and sits on the circuit board and around the gasket seal. The oil leaches out from the grease and is doing its job. You can normally tell this because water entering the motor is seldom clean.Yes, the grease does look rusty coloured. There was some water ingress along the casing seal so I carefully checked the gears and cpu board. There was no rust pitting on the gears but the very small amount of water has me worried. Basically enough water to get one end of a Q-tip damp. I believe the water may be entering through the casing seal in spots.
The inside was dry and clean, other than a very small amount of water.
Cyclo Chrome nailed it for me. Well done! Juan answered my “silly” email questions within minutes or during work hours. My parts were received amazingly fast and shipped across Canada in days (2). They probably used our Olympic Polar Bear (aka, Canada Post Express) or the only Star Trek Transporter in the world. (William Shatner’s house).Thanks for the shout out for Cycle Chrome, those guys have put a lot of effort into learning about eBike motors, including flying over to the UK to spend a few days training with us. As for your water ingress, I think what you perceive to be water is oil. This is a very light clear oil that looks just like water and sits on the circuit board and around the gasket seal. The oil leaches out from the grease and is doing its job. You can normally tell this because water entering the motor is seldom clean.
You can see that water has entered into your motor through the right hand crankshaft bearing and emulsified the grease, turning it grey.
You were correct with the torque settings for your particular motor, but if you have the later Gen 4 "Smart" system motor, these have a 6mm machine screw with a standard T30 Torx head. The torque for the "Smart" motor is 10Nm +- 0.5Nm for first assembly (new motor) after that the torque should be set at 9.5Nm +- 0.5Nm.
What you said about the moisture makes sense. It was a very clear liquid that looked like water. I wasn’t too concerned about it because it was only found around the casing perimeter.
The grease around the cog(s) had two different colours though. I carefully inspected the rust-coloured grease but found no indication of rust developing. I applied a small amount of grease in areas that may have needed it before I closed up the casing. Removing the crank or cpu or some bearings is above my skill level. I think I will keep my motor servicing to a bearing seal kit (which I will install) and keep another kit as a spare. The Bosch grease included in the kit (greenish) is almost empty since I’ve used it several times.
Installing the bearing seal kit is relatively easy if you have the right tools. The cir-clip can be a little tricky though (any tips or secrets for easier removal?). I may modify one of my cir-clip tool for this particular cir-clip. (Grinder, file, etc). What ever it takes. Using two common screwdrivers is possible …but it’s tricky.
Thanks again for the help and a big shoutout to Cyclo Crome for servicing our eMTB motors in Canada.
