20мм. I have a 29x2.4 wheel
It's looks the bigger travel, 55 mm shock stroke will likely clear easily with a 27.5 x 2.8 rear wheel!👍
I'll pick up the 15ah battery next week. The weight of the battery is 15ah - 2150gr, the weight of the battery is 10ah - 1500g.
So, you have the downtube battery as 410 Wh?
Also, what size frame? Large or medium?
I think the problem LAnton is seeing is the pivots binding carbon on carbon, not the tire striking the frame.
But the eye-to-eye fitment is still 210. It should still accommodate a 55 mm stroke. So, the frame friction of the rocker arm hitting the seatpost mast is unlikely. But we'll see for sure soon! 🍻
    668K
