Review Kryptonite New York Fahgettaboudit Chain
nick077
7
Us
Product Image:
Product name: Kryptonite New York Fahgettaboudit Chain
Price paid: $98.86
Score (out of 10): 9
Review: I recently bought a bike lock name Kryptonite New York Fahgettaboudit Chain and Disc Lock by watching a review from Best Chain Bike Locks You Can Trust in 2023 (Uncuttable)
I'm very much satisfied with the quality of the lock. This lock is mainly made for scooters, but you can also use it on your bike. The 5-foot-long, 14 mm 3t hardened manganese steel chain that makes up the Kryptonite New York Fahgettaboudit Chain has a nylon sleeve attached to it. A PVC-coated 15 mm steel shackle disc lock holds the chain in place.
It has two different versions available on Amazon. 1415 and 1410. 1415 is inevitably heavier and longer than the 1410 version. Other characteristics are identical.
Doomanic
🛠️Wrecker🛠️
8,492
9,975
What's the weight of that thing? How many discs does it compress in your spine?
Semmelrocc
243
597
This is my current lock btw. It is so secure that I often don't take it with me in favour of less spine compression. :LOL:
Tony4wd
221
187
Keep in mind that an angle grinder will make short work of any chain. If your bike is on the street I'd consider incorporating one of the new compound metal locks like the Litelock X1 - having to change grinder discs a few times is a big deterrent.
galaga187
796
597
Wroughton
Hiplok brought this to Sea Otter & had gone through 5 cutting disks without cutting through. I've cut enough metal with cutting disks to have been impressed... If I had a need for this, I would buy it:
Might they just saw through the things it's locked to?
2WheelsNot4
893
692
Certainly the business that one. But 250 quid hmmmm rather pricey, and its locking capacity is not that much that I think you'd struggle to get it around a pole and your frame. 5 3/4 long by 3 12/" is way too small.
Maybe as an additional lock, between the rear wheel and frame to immobilize it so it cant be rolled or ridden away.
8,698
I have no interest in carrying a bloody great chain and bike lock. My Kryptonite New York Noose (12mm chain) stays in the garage where it locks onto the Kryptonite ground anchor via a Kryptonite lock. When out and about, I never leave my bike unattended - not for a second! I also use a Kryptonite cable and lock to secure the fork.
Eliadn
82
35
Croatia
At work I have the big abus granite U lock together in combination with abus folding lock (around front wheel, and another layer of security). However I wouldn't leave the bike outside overnight. Angle grinder will make short work of any lock (apart from already mentioned hiplok).
525K
