Pole Voima Mudguards
Hiltix
Swissalps
I was wondering how to do with a mudquard in the back. Has someone possibly already evaluated a solution for this?
Can't speak for @Murphius, but yes, I personally do.
It's a bit tricky to assemble, but works flawlessly.
Recommended.
Thank you very much. Yes, when I watch the video of him introducing the Mudquard, I can well imagine that it is a bit fiddly to mount. Think I will give it a try.
I have one as well, older ribbed short version though. Looks like there’s new smooth redesign available now, not sure how it changed, so all my words are for older versions.
it sits just fine once installed, quality is good, it’s flexible. It has cut-outs in all the right places, doesn’t touch frame at full compression, and generally only contact points are mounting holes.
I wish logo was smaller.
Top portion has a lot of mud clearance on top and sides.
However it doesn’t have a lot of vertical mud clearance at the bottom part on my setup (2.4 wt minion on 30mm internal w rim), not sure how it’ll work in sticky mud.
It’s very flexible down there and I think even if seriously clogged it may work.
I don’t ride in mud, it’s mostly dust here in socal, works perfectly for that.
Despite small issues it’s totally worth it. Good addition and keeps a lot of bearings clean.
BEDD726C-7897-40CA-AAE0-9BEB6FC7CC39.jpeg 1EC35738-5EB9-43AC-BF46-3762824AF1C2.jpeg
Thank you very much, that is certainly a possibility. Do you use this Mudquard yourself?
I used it as well, works great and it’s specifically made for the Voima and Vikkela.
Perfect fender! I use the rear one for my first generation Pole Voima. Also look at the led control holder, if you want to place this in the center of your steering bar. Recommended!
SKS Mudrocker fits quite well, 275. Unfortunately zip ties needed and cut-to-length... an anchor, still around 250 g...
Had VisionVelo before, but after brake change it wasn't as solid as new anymore, kept falling of, So I'm now waitig for next update...
I have the vision vision. I have the K1 frame at the stock velo vision mudguard bottomed out on the frame before the shock bottomed out. It also split along the a 3d printing line. Slawamir redesign and has sent a replacement under warrantee which I haven't fitted yet. So his service has been good.
With that said, I don't think the 3d printed mudguard is as robust as a standard plastic mudguard. Its there for a good time, not a long time.
    Join 43,181
