Jorva 1983
Hello. i am having some problems with the rear brake on my levo.
i noticed this after getting my new frame.
i have bled it with the sram bleed tool myself. and there is no air left in the system.
the lever is very firm with the block from the bleed kit installed. In the rear calliper If there still was air in the system i woud also feel it With the bleed block installed.
but when i instal the brake pads an squeeze the lever in need to turn the reach adjustment to the end to even have a bit of a functioning brake. I also noticed that it was adjusted like that before i started bleeding it. so it must be something i adjusted like that and did not really notice before.
i am almost 100% sure that there is no more air in the system, so i started looking at the rear calliper and the pads. What i noticed is the folowing. When i pull the lever the pistons come out push the pads out (yes thats how they work
). But when i release the lever the pistons completely return into the caliper. And this is what causes the strange feel in the lever and the need to adjust the reach on the lever to the end…
so what can cause this? is the spring that is between the pads to strong or bent to cause the pistons to go completely in, causing the long reach on the lever… Or did i mess something up with bleeding it?
i have read more then once that sram brakes are the worst to bleed ect... Thing is i have a set of guide LT brakes on my daily bike, and i have shortend the hoses ect and recently bled those to and these are as firm as it gets almost like the hope brakes on my old mtb. So where do i look now? caliper alignment, the spring…
