Rise H Range extender. Anyone know how it works?
John_A
Does it run in parallel with the main battery or do they somehow run sequentially?
sequentially, if you see battery % on a garmin or similar device, you get 100% of both though, and it will not indicate when it switches between them. You can push the battery level button on the extender to see how much of it you have used though.
Thanks for that may get one
Yes, it runs sequentially, first using the range extender and then the internal battery. The display initially reads the percentage on a combined basis (extender plus internal battery), then once the extender is depleted the display goes back to showing percentage on an internal battery basis.
