Rail (625Wh) Battery to motor connector cable
Philly G
EMTB Pro
New Zealand
Hello everyone, does anyone know the length / part number for the cable connecting the battery to the motor? (2020 Rail) I haven't had the chance to pull everything to bits yet but I want to order the part today to make sure it's here for Christmas...part number is BOS 12700165xx depending on the length...there's quite a few variations. Wouldn't matter if it was a bit longer but of course no good if it's too short...
I know this is an old one but trying my luck anyway. Do you know the correct length? I wander to order the part but won’t get chance to pull the motor until next weekend? Can’t find the length in any of the parts diagrams.
Cheers
I forget now where I bought mine from, tried to search through my emails. Will be able to tell you the length when I get home tonight
Cheers
Found it! I replaced two cables on my 2020 Rail, first the Purion display itself with cables, and the one going from the battery terminal to the motor. For the Purion, I got the 1500mm cable. For the battery to motor cable, there are several different lengths. I think the original was the 410mm, but I got the 520mm length, because I wanted a bit more slack so the cables didn't have to bend so sharply to connect to the motor.
And for the display
Hope this helps
Awesome! Thanks bro. I will do the same and order the 520 for the battery. I also recall things feeling a little tight back there when I last had the motor out.
    Join 43,270
