What is the perfect EMTB?
Mteam
1,791
1,728
gone
Particularly the lightweights seem to be most afflicted on trail rides.
Disagree - I notice the speed limiter much less on my trek fuel exe than my bosch cx gen 4 powered wild fs.
Thr speed limiter isnt an issue at all on the trek.
michael.kozera
New Dad ! 👶
Feb 3, 2021
106
203
calgary
over the years of building many e-bikes, i believe that i have built the ultimate e-bike. and what ive built, no one has even come close IMO.
-BBSHD (1500w) motor
-1,600wh (1.6kwh) battery , (126 samsung-E 3500 cells, aranged in a 14S9P 52v pack)
-BMS is a 40A 52v with thermal cutoff.
-230mm rear travel (fox) with titanium spring
-203mm front travel (rockshox)
-220mm front rotor, 200mm rear, quad piston Avid brakes
-100mm dropper post
-27.5 FLOW rims, with johnnywtts 2.8" e-bike tires
-triple LED projector style lights (45w total) with triple horns
-11s drive
- comfort gel seat and gel grips
-62lb's (28kg) total weight
- aprox 90 km/hr top speed
-range as short as 50km as far as 400km's
the only thing i would change if i was to do it agian would be maybe make it a 29" instead of 27.5, or perhaps a mullet. and perhaps a larger battery as 1,600wh can get me 400km's of range, but sometimes when im riding like an ape, im getting under 50km's, so i think 2-3,000wh would be ideal, but then you adding more weight tho....
perhaps making it carbon would bring the weight down, but 28kg is very light considering the specs.
20210222_141033-jpg.54410
now if you a weight weenie, and a bike has to be light weight, well then i believe ive also made the ultimate light weight ebike, at 15kg and 700wh battery with a 800w motor
29er
130mm in the rear and 140mm in the front.
200mm front and rear brakes
20210222_140659-jpg.54042
20210222_140605-jpg.54039
only thing i would change would be to add a larger battery, 700wh is plenty as ive gone over 300km's once on a single charge but i dont think i can physically fit any more batteries inside that frame, its pretty maxed out haha.
jgusta
118
47
There isn't one
This!
So, back up ebike is your best answer especially if ride regularly/weekly. My ebike down about 2-3 months/year at least waiting for replacement parts and what not. If fully dedicated e-biker (not riding regular bikes much at all anymore) than back up bike the ticket. I am on regular bike full time now over past 6 weeks and it sucks, especially as I bounce back from Covid.
jgusta
118
47
This!
22’ Levo Turbo or Kenevo SL on closeout now would be my recommendation. Both 20% off.
dewbage
Very true!
At the end it's the best compromise which you will buy.
Ideal for me personally would be:
- 150/160 travel
- 750wH battery
- 60 to 90nm
- no more than 18kg
- powerful, light and reliable motor
Hopefully battery tech will develop further, so we can have lighter battery packs, which would be a real blast.
New Orbea wild gets close to your specs at the 20kg range
VWsurfbum
🤴King of Bling🌠
Jan 11, 2021
1,374
2,038
England
-100mm dropper post
-11s drive
29er
Wow that tracer is a beast!
I cant see the motor in the Scott? is it a hub drive?
VWsurfbum
🤴King of Bling🌠
Jan 11, 2021
1,374
2,038
England
a very small hub-drive yes. ultimate stealth ebike build.
the battery, bms, and controller are in the frame. both the bms and controller are attached on this aluminum cooling plate, the plate is also the access port for the battery.
20210222_140728-jpg.54044
Thats awesome.
JW427
17
17
Essex
Trek Rail... is a very good bike, my 9.7 is a lovely ride the range is awesome, the Bosch motor is near on silent and the power delivery is very satisfying ooooh the surge up the hills is vey addictive :cool::cool: if a certain Spesh rider we know was on here he would push your mind towards the Kenevo bikes ;)
Your more than welcome to come try my Trek Rail out around here, Langdon hills is a good proving ground.
VWsurfbum
🤴King of Bling🌠
Jan 11, 2021
1,374
2,038
England
Oh he's on here and we have lots of messages with him and Mr. Stump trying to convince me to get an Audi.
Stihldog
Handheld Power Tool
2,948
4,168
Coquitlam, BC
Some day I’m gonna post some criticism of the Bosch CX Gen4 motor. Whenever that happens. My Rail 9.7 was the first through the LBS in 2019 so it may have got some extra attention at the factory. New and un-tried products are always risky and all I could do was ask questions and research as best as I could. So far so good. But with the amount of upgrades I’ve since added it’s becoming difficult to justify a new bike/tank.
Dave_B
1,420
1,542
Newquay
you rode my Rail Ian. I’m surprised you don’t have one already with all your crazy purple bits on……
Dave_B
1,420
1,542
Newquay
You could buy a lower spec Rail with the larger battery and swap out all your bling from the Heckler and sell the Heckler as frame only.
Dave_B
1,420
1,542
Newquay
But for comedy value, buy a Spesh. Just imagine you Dave and Tonksy bombing round on the same bike…. Will be like the old days when we all had Hecklers 😂
jgusta
118
47
Rail/Bosch4 definitely needs some revisions by Trek and Bosch. Bike does ride nice when working, problem is, it is failure waiting to happen (motor/electronics/motor mounting hardware). I personally think the Rail is not up to snuff to be pushed hard. If lightweight or timid rider like my buddy is on his, then likely fine only
Doomanic
🛠️Wrecker🛠️
8,484
9,963
That may be your opinion. The thing about opinions is that they're like arseholes; everyone has one and the often stink.
jgusta
118
47
Not opinion, but user experience rather in past +1.5 years. If no issues, keep hammering and don’t sweat it
jgusta
118
47
Care to elaborate?
18-19 months use…3 new drive units, 2 new head units, one replaced main frame, one replaced rear end and one complete replaced Rail pending (waiting +6 weeks so far) and another drive unit (4th) with thicker internal mounting bracket for prior Rail.
Just my “opinion”, so not worth reading or considering however.
jgusta
118
47
Interesting. I’ve had a few niggles with mine which I hope are ironed out now.
Me too. Rail is definitely a fun bike to ride of course. Just hope Trek/Bosch gets things sorted out so bike can be handle some loads/use mostly mechanically/electrically trouble free in the future. I know I miss mine. Feels like forever without it. Regular bike is just not as fun
Doomanic
🛠️Wrecker🛠️
8,484
9,963
2700 hard miles in all weather conditions on mine. A couple of issues over that time but nothing that stopped me hammering it every ride. The motor failed in the bloody garage though! 🙄
jgusta
118
47
Nice! FWIW, no motor failure here, just the chincy motor internal mounting bracket that kept coming loose despite new hardware and complete drive units over past 1.5 years. The bolt heads of motor bracket would eventually shear off despite Trek installing replacement motors and checking torque periodically. Cause of loosening of bolts from the thin metal plate, the wiring to lower battery plate would get ripped out and crushed as a result, what caused my most recent failure with bike being dead since.
Along with new complete 22’ Rail pending arrival, Trek/Bosch plans to replace the former drive unit again with thicker mounting bracket for old Rail to prevent this from happening again and compromising the rest of bike internally. So hopefully two Rails in my possession soon (think everyone could use a back up ebike if ride fairly frequently).
Just an aggressive trail rider here I suppose on mixed terrain with plush suspension (coil), sturdy wheels/tires with CushCore. So not sure why parts always coming loose internally and getting destroyed? Since ownership of Rail in past 18-19 months, I do have over 5,000 miles and about 1.2 million vertical feet. So the bike has seen some use.
Rando_12345
198
263
France
Going back to the original question, my dream bike, based on roughly achievable aspects from existing bikes would be:
Spesh Levo geometry and adjustments
Full 29er, 160/160 travel (Similar to SCOR)
Canyon Spectral On 900Wh battery
Orbea Wild Weight (~21kg)
Any motor so long as reliable (i.e. not a Brose), with a 5 year warranty (this is actually the most far fetched aspect of the build)
Giant/Canyon pricing...
524K
