Power stations
Hicksy 92
Stonesfield Oxfordshire
Hi all , anyone charging there ebikes with a portable power staion, ideally I would like to charge 2 at the same time while they are in my van , if so any recommendations welcomed .
thanks
That reminds me, got to service my portable 2.8kVA petrol generator in case the shit hits the mains power fan this winter.
Lots of Black Friday discounts out there on power stations right now.
Just remember that if you have say a 500watt hour battery you need at least a 500watt hour power station if you expect to charge it completely and for two bikes double that. The inverter in the power station would have to be rated at 1000w.
It might be cheaper to get a small 2000w petrol/propane generator although it would be noisier.
Yes definitely cheaper , but would like to be charging while on the move . Just wonder who’s using what brands , models etc ,
I’m using Ecoflow River Pro. Can charge the battery two times, but I have a small battery Specialized Kenovo Asl.
New Ecoflow models have LiFePo battery and those have about 3000 battery cycle. So they would last longer than your ebike.
You can charge in the van while you are driving with just an inverter to your cigarette lighter, maybe not two bikes depending on your cigarette lighter amperage.
thanks
I use a Jackery 1000 explorer which I'm really happy with and has two 3 pin ac outlets so I can charge 2 bikes at the same time
Yes they are ok. The Delta Max is the same just twice the capacity.
Yeah I think if I bought another I'd go for a bigger capacity but I got mine at a reasonable price of £550
I have 2 504wh batteries for my Merida e160 and it'll charge both as long as they're not totally flat
However I've just bought a new Cube stereo hybrid 160 with a 750wh battery so a larger power station would suit me better
The lighter/power socket in most vehicles is limited to around 120 watts, highest is around 160. Most bike chargers are going to consume more than that. However, your idea is solid if it's wired to the vehicle battery. It's by far the cheapest, and mostly infinite capacity. A 400-500 watt inverter is very inexpensive.
My charger is a 2amp at 120v that means it would most likely work on a cigarette outlet. Like I said it depends.
No, there’s absolutely no chance. Even without considering losses, that’s 240 watts, or 20 amps at 12v. That math is volts times amps is watts. You can reverse the equation. And simply put, the amps at 120 will be 10x at 12v.
But perfectly acceptable when hard-wired.
There are cigarette lighter outlets that can handle it.
It's impossible to prove a negative, but I think that's false. The highest I've ever seen is 15A, and that's rare. It was also backed up by scary-small wires. What car have you seen with a 20A outlet? Or are you talking about an aftermarket add-on, in which case you have to go to the battery anyway? I was shocked to see that my Tesla is just over 15 which is high, Jeep 10, Smart car 8.
First blurb from Google...
10-amp
Most cigarette lighters run on a 10-amp fuse that allows for 12 volts or 120 watts of power output at maximum. There may be some variance on this depending on your vehicle. Check your owner's manual or the cover of your cigarette lighter socket to find the specific output for your vehicle.
10-amp
That's right. They will put out 150W even with an inverter which won't run a bike charger that I've seen.
thanks
I have a blog and some video guides to this, which lets me go away for 2 or 3 days of biking even when it's not fully sunny, using a Bluetti EB150. I also have a much less portable AC300.
You need to do a survey of the appliances you want to run. Each device will have a label printed on it with the voltage it runs at and the current it requires. You will find the small air conditioner pulls a lot more than your other devices. Then add up the requirements of the devices you will have on at the same time. You can't start to do anything until you know what you need.
The aferiy 2000wh has caught my eye recently.
Can be had for about £850 with a discount code, also from Amazon.
Would get me 2 charges of a 700wh battery.
Even pricing up individual components, battery, charger, inverter etc isnt much cheaper than this.
Additionally I could run bits of my house during the day after charging up on cheaper overnight elecy.
I use a BLUETTI AC200 MAX Li Fe Po battery charged by an Off Grid TREK 220 watt folding solar blanket. Yeah, a very spendy setup, especially the outstanding OGT solar blanket at US $1,700. but well worth it for backcountry car camp E-MTB trips and power outage situations to keep refrigerator/freezers running.
On a recent antelope hunt in remote north central Nevada this setup kept my TWO battery, AWD E-CELLS Super Monarch Crown bike batteries charged and ran a small cooler all day off the BLUETTI which was kept fully charged by the solar blanket. (Yeah, I'm spending my daughters' inheritance.) :)
Maybe silly question but charge time from portable power stations like Jackery, are they any different from charging at home from AC outlet?
And perhaps on a related note, any way of speeding up Orbea Rise M series charge time. 5 hours full charge is slowwwwww
I use my Jackery explorer 1000 occasionally to charge my bike and it appears to take the same amount of time as using the mains .
One thing to note tho if you are considering buying one is capacity, my Jackery is 1000wh and my bike battery is 750wh but for every 10% charge it takes 10% out of the Jackery.
So due to losses through the inbuilt inverter my Jackery will only give me 1 full bike charge from zero.
The only way to speed it up is to get a charger with a higher capacity. The most effective way to charge is a DC to DC charger, like EVs use. But that's a bit rare with bike batteries (common with remote control vehicle batteries). The charge time won't change significantly by the source type (inverter etc).
    Join 43,198
