Sticking power button
Plutohora
Most of my rides are wet and dirty. So far the power button just keeps on sticking down. WD40 doesn't shift it and I don't want to damage any seals using a screwdriver tip. Any tips????!!
Then did this
It was halfway through a ride, just as me and the Mrs were leaving a cafe. I think it had stuck down from when I switched it off. I sorry of pressed and jiggled it and it eventually popped back up. Worked ok then.
Mine did that the first time, press at angles and jiggle finger pressure fore aft etc. This time it was like it was peak gritstone cemented down. I set off thinking sod it I'll ride sans battery but then decided to retry
I tried the trick today where you roll the rear wheel backwards 3 times to see if the system would stay on and it worked! You have to make sure they are continuous.
It works easier if you use a cable tie to tie right crank to chainring and pedal backwards for some time. I always take some plastic cable ties with me (low weight and can help to fix few things in my routes).
    Join 43,210
