Levo Gen 3 Needed spacers for water bottle bolts (carbon Levo)?
RickBullotta
1,786
1,524
I don't use a water bottle, so I removed it and reinstalled the bolts, since it seemed that there's a detached part inside the frame to which the bolts attach. I noticed that there was still a good bit of movement (and a rattle). I added two thin washers and spacers and things snugged right up. Is this normal though?
Snrbrtsn
215
166
Uk - Scotland
Ah! Interesting,
I have my water bottle holder removed and noticed recently a rattle whilst on loose gravel or rocks
Looking at the schematic, I guess I’d best copy your thinking (thanks!) as I need the frame clearance for mounting bike on car carrier (better check if true, otherwise refit bottle cage)
RickBullotta
1,786
1,524
Ah! Interesting,
Although I'm dropperless now, mine came with an AXS post so almost nothing at all to hold that bracket in place! Hopefully a couple washer will quiet that rattle for you.
Snrbrtsn
215
166
Uk - Scotland
Thanks for your kind words
Removed battery & scratched head, dumb moment had, mines a 21 and the cables run through the diagonal - Rookie error on my part, never the less I’m sure I’ll find my noise I thought it derailleur clutch but NO!
527K
