Motorcycle stand style for eMTB
Bad Mechanic
Kensington, MD
My motorcycles used stands which would pick up by the rear swingarm like this:
It makes it really easy to store the bike and do basic maintenance on it. It's also really easy to put the motorcycle on the stand since it levers it up. I'd love to have something similar for my eMTBs, however this is the closest thing I could find:
www.amazon.com/dp/B00G7ZO3GE
The problem is you need to lift the back of the bike up, position the stand, then set it down in the stand. Does anyone know if someone makes a bicycle stand which levers the bike up like the motorcycle stand?
Why not use a feedback sports stand? When not riding just hang the bike by the nose of the seat over the stand.
I have a dodgy back, and generally avoid lifting. When I need to put one of the eMTBs in my work stand I have a small ceiling mounted electric hoist I use.
The bike stand would be mostly used for storage. I've tried "roll-in" bike stands, but they don't hold the bike very securely at all.
You can lift the front, clamp it on the balance point, then rotate it. If your back is too "dodgy" to lift your ebike onto a stand to do this then you really shouldn't be riding it. Just sayin'
[/QUOTE]
I've just bought a couple of Willworx Superstands. They are the roll in kind but they are very stable, not really suitable for maintenance but great for storage. Easy to roll in and out and very secure.
I did have some roll in stands from Halfords and they are pretty useless. I've been putting up with them for over 18 months but my Whyte fell over last week and the pedal took a nasty bite out of my wife's brand new Levo so that was the last straw!
That stand looks MUCH better, and I'll probably end up picking up a couple.
These are the roll-in stands I'm currently using and they're pretty useless. They might work okay for a road bike, but they suck for an eMTB.
That looks practically the same as I was using. A decent fart would knock the bike over!
Is this the willworx stand? Does it require a push with the foot when one pulls the bike out? Seems like the stand would cone with you and the bike.
Is this the willworx stand? Does it require a push with the foot when one pulls the bike out? Seems like the stand would cone with you and the bike. View attachment 91171
That's the one, it comes in different sizes for different width tyres. I got the superstand 12 to 29" which is supposed to be suitable for up to 2.5" tyres My 2.4" front tyre goes in and out without the stand moving at all.
My wife's Levo has a 2.6" front tyre so that is a bit tighter. The easiest way to get that out with minimum effort is to stand in front of the bike, place a foot on the base of the stand and push the handlebars back.
So apparently only completely healthy people are allowed to ride eMTBs? What are activities do you think only 100% healthy people should do?
I bought one to try out and it should be here Friday. Thanks again!
If it work well, I may add caster wheels to make it easy to move around.
If you want a motorcycle style stand I’m sure a local engineering place could make you one, or modify a motorcycle one to fit your bike. Doubt it would be cheap, but would last you forever!
I don’t need a “lifting” stand, just a storage stand so I made my own out of timber wall studding. Really stable and the bike rolls in and out easily. Adjustable width too if I decide to fit wider tyres (the silver bolts underneath slide in a 1” slot).
FJM Mk 2 Home | FJM Custom bike stands
UK-based but they ship to the US, might be expensive though.
It's not clear from the photos on the website, but you can attach the stand to the bottom bracket in its folded position, with the bike entirely on the ground, then push the bike forwards and the stand pivots into shape lifting the rear wheel.
I couldn't stand the idea of spending my hard-earned cash on a noodley POS made in China, so I made my own. I had plenty of 2" pipe, 1" tubing, and paint, so the total cost was $10 for a bag of end caps. I made two of these. They'll accommodate a 29" x 2.8" tire, either front or rear will fit in the stand.
View attachment 91211View attachment 91212View attachment 91213
I made a couple similar - a bit rougher than yours out of some old pallets but put 3 cheap small castor wheels under them & they're brilliant as you can move the whole bike around the garage & not have to find somewhere to lean the bike around.
I use one of those black and orange stands and they are good for spinning the back wheel. It wouldn't take much more weight though and certainly no sitting on the bike. As you say, the rear wheel still has to be lifted, and for me the chain always fouls on the chainstay support, further causing more effort. If your back is that bad then I'd probably avoid them. (I get it).
During Covid lockdown when everything was in short supply I made this from bits of timber from my offcut stash. Very stable solid stand.
