£4999 2022 Cube Stereo Hybrid 160 Punches HIGH!
The bike is a LOT louder than the Trek Rail, that's why I mentioned it. I suspect some of it has to do with anti rise / squat and pedal kickback pulling on the chainring when the suspension is moving through the travel.Nice video.. but I think you're just nitpicking with that rattle noise. I get the impression you're trying to convince yourself that compared to Trek Rail you have and had to cough up extra $$ there's got to be something lesser with the Cube. Why wouldn't you do a comparison of that different rattle noises you show around 5:10 in your video compared to Trek Rail? I kind of suspect you'll see the same imperfections in Trek....
Got your point - and thanks again for making the vid. Perhaps I'm a bit biased as I love my Cube 160 TM (that's my 3rd ebike by now) and if it was me I'd put the accents differently than you - that's however your vid and your freedom to express your opinions. That's not to say I think Cube it's perfect. I have recently discovered that after ~700 km it developed this creaking noise from somewhere in a suspension - something similar to what you can see in this YT vid: .The bike is a LOT louder than the Trek Rail, that's why I mentioned it. I suspect some of it has to do with anti rise / squat and pedal kickback pulling on the chainring when the suspension is moving through the travel.
My job is to nitpick, thats kind of what I do in the videos. Like the rail video, nit picking about the battery release keys that bother me for the battery, the poor integration of the display etc etc.
There's plenty of other video channels that wont mention any faults on bikes out there, but no bikes are perfect and I think its worth mentioning stuff like rattles (that some people dont mind, others wont buy a bike because its irritating enough!)
Nice. Is that vibrofiltr heavy?On my 160 TM I only had to adjust the bottom srew, now the battery cover sits perfectly tight
As for frame noise/ vibrancy, I stuck some damping material behind the batterymount/ cablehousing, helped a lot IMOView attachment 90622View attachment 90623View attachment 90624
I like my 27.5 wheels, but would have preferred a front fork with a 10mm higher connection bridge, to allow a 29x2.25 wheel and tyre.Cannot believe Cube don't have a 29" version of this bike. They must be one of the only manufacturers left that is using a F&R 27.5" bike
I had to change the saddle right away on my 2020 Stereo. Got the Ergon SMC Sport Gel saddle and its way way better, it also moved slightly further back than the stock on so that along with rider bars and that sorted the reach issue out for me.I’ve only been for a quick ride on my TM but that saddle!!!! Probably the most uncomfortable one I’ve ever had. It’s now being replaced. One thing I wasn’t expecting was the large frame feeling a bit short. I’m 6ft but must have monkey arms as I feel like I need to stretch out a bit. Have ordered a slightly longer stem and hopefully the new saddle might make a difference as well.
I did order a slightly longer stem but sent it because the bars and saddle alone did the trick.Have ordered some riser bars too so hopefully it’ll all be sorted for reach after that.
Haha yeah I knowHopefully that’ll be the same with mine. £50 for another 10mm length seemed a touch expensive.
The chart says I fit an M....One thing I wasn’t expecting was the large frame feeling a bit short. I’m 6ft but...
Hi my 160 action team made that sort of noise , I traced it to the seals in the headset , just loosened it up and smeared some grease in there and the noise has gone now , it’s been quite for months nowI have the 2020 version and didn't notice the noise until watching the video about the 2022 version
Whilst tuned into noises on today's ride I've also now noticed a clicking from the front, could be headset or forks, not sure yet so that will need investigation, seems to happen when the forks are being used but that could also still be headset related
And FWIW the 27.5 wheels are the exact reason I have a Cube Stereo, I'm only 5'9", I look ridiculous on 29" wheeled bikes and I ride a lot of flat trails so it's perfect for that and does just fine on the downhill sections of trails. Not everyone wants to constantly bomb down hills soaking up roots and rocks so I really hope Cube keep the 27.5" version of the bike going for many years![]()
Ooh nice thanks, I'll do that asap then.Hi my 160 action team made that sort of noise , I traced it to the seals in the headset , just loosened it up and smeared some grease in there and the noise has gone now , it’s been quite for months now
I'd like to see bike models be offered in both wheel sizes. I love 27.5 and would hate to be forced into 29" just because a manufacturer decides it would be better for me.I can't believe manufacturers don't use both 27.5" and 29" wheels on the same model depending upon the frame size. I'm a firm believer the wheels should scale up with the frame. Same with the size of the discs. Of course, doing these sensible things would have the unintended consequence of the larger frame sizes costing considerably more. But it makes a lot of sense.
I have the 2020 160 and it has 27.5" wheels.I think Cube did that by offering the 140 and the 160.
Very similar, other wheels.
