My H15 started creaking under load after about a month, so I decided to do the "quick disassembly" of the upper linkage arm. What I found was the arm, the bearings, the axle, and the bolts were all caked with greasy dirt. I cleaned it all up, applied some fresh grease to the bolts, and re-assembled.
I have one comment, and one question below.
The comment - I ran into an interesting hiccup during reassembly. On one side, the large "shock extender bolt" did not sit flush with the arm after torquing it down to the specified 15nm. The threads did sit flush, but the head of the bolt was sticking out a bit. I pulled that arm off and discovered that the larger bearing appeared to not be seated all the way in the arm. There was about a 0.5mm to 1mm "gap" that had filled with the aforementioned greasy dirt. I cleaned out the gap, and did a few gentle taps while holding the arm using the bolt - that seemed to seat the bearing a bit better. After reassembling, the bolt head now sits flush again. I wish I took pictures or remembered if this was how it was before I took it apart. Maybe a bit of sloppy assembly from the factory?
Seems like my creak is gone though!
And the question - the axle seems to be seated all the way into the arm on the left side, but on the right side (thread side) it is almost, but not quite all the way seated into the arm. I did use the preload tool. Is this normal?
