For the Altitude, I spoke to my LBS and they said any 34T 24mm spindle cranks will work. These ebikes are not like usual ebikes where you need specific cranks.
I'm thinking of 160mm cranks if I can find some.
Yeah will do. I noticed quite the difference when going from 165mm to 155mm Miranda cranks on the Decoy.Thanks for the info. If you find something that works please let me know.
I'll double check. I have to admit they have got a few things wrong when it comes to ebikes...Are you sure about that? You have to install the spiderclutch on your cranks. AFAIK the clutch can be installed on RaceFace cranks. There's also a version for SRAM cranks but I'm not sure if it's compatible with the current Powerplay generation since all the models use RaceFace cranks.
Any progress with the shorter cranks?
The stock 170's on my altitude are too long imo, and my LBS has problems even finding a 165mm. They contacted raceface and got a pair of 165's but the spindle was too short. Go figure.
Anyway, i liked the 150 miranda's on my previous spectral on, so would be great to have something like that again.
Hi everyone!Oh, and RM customer service is full of shit - ....
Specs as from Rocky Mountain
Race Face Aeffect Cinch 34T | 24mm Spindle | Crank Length: SM - MD = 165mm | LG - XL = 170mm
I got the same impression...Another problem with those 170mm Race Face cranks is that they apparently use the same crank mold for 175 and 170mm. The only difference is that the 170 has the hole drilled in a different place. But effectively the 170 crank is just as long as the 175. Thats not helping either!
The new version no longer does that it’s a true 165 or 170.I got the same impression...
sorry, in what sense? thank you!The new version no longer does that it’s a true 165 or 170.
do you mean the ride4? because from position 2 to 1, the bottom bracket goes down ...Ok, so one thing i did is to change the rear suspension flip chip from position 2 to 1, and that raised the bottom bracket about 5mm. That should be somewhat helpful at least.
The Aeffect R's are the smaller 24mm BB cranks just like the standard Ride cranks that come on lower specced Rocky Mountains.
So if they are similar to the Ride cranks you must buy them with the right spindle length from factory (no aftermarket swapping to a different spindle length possible, unlike the bigger 30mm cranks). And that means you must have the AM83(156.25) spindle, which is OEM Only. Good luck finding those!
In my other post ive linked to a document that might be of interest, it explains spindle sizes.
