Cube 2022
I don't know how good or not is the battery for now, only make a first ride after i have take it from the shop.
The tyres have so much grip! crazy what it's possible to climb with it...
will see with the time but for now I'm very happy with it!
140 TM 750
Well here's mine: Suddenly there was a 160S 750Wh L available in the shop.
The first impression:
and a few modifications I did:
Hey Guys what setup ride you on the Float X ?
I have the Stereo Hybrid 140 TM and need a good setup for my Float X...
Thanks Andi
The setup depends on your weight, so unless someone is the same weight as you, their settings will be no use to you.
As above
Look at the recommendations from the manufacturer of the fork for
your weight, and start with those.
Then tweak as required during your first few rides.
The cube store bike mechanic said something about "double in the back then in the fork"
I guess he did what he said, the bike behaves good.
Now I am in the phase of doing what the last sentence of lightning said.
Shock same as fork, start at the shock manufacturer or bike manufacturer's recommended settings for your weight and tweak after riding, change the air pressure in small amounts say 10psi then test again
