Wanted Shimano 31.8 clamp for SC-E7000 (part #Y79G01020)
Bigtuna00
CA
I'm upgrading the bars and stem on my wife's Orbea Rise H30, and will be switching from 35mm to 31.8mm bars. Hoping someone might have a spare 31.8 clamp to sell, or we could swap clamps. I know the display includes both clamps when purchased at retail so if you bought one and are using 35mm bars you likely have a spare clamp hiding somewhere :)
They seem to be for sale on some Japanese Yahoo shops but that's about it.
I'm in California, USA FYI.
Thanks!
Had exactly the same problem when I replaced my wifes bars with a fat version, I just used a longer screw in the existing clamp which worked and because it was underneath you cant see it.
I found an SC-E8000 on ebay so I'm upgraded her to color instead :P
In case anyone finds this thread, I completely forgot that the SC-E8000 is NOT compatible with the EP8 motor. You can't swap from SC-E7000 to SC-E8000. There are several other compatible displays for EP8, but the SC-E8000 is not one of them.
However with that being said, even though the SC-E8000 clamp has a different part number (Y71F00002), it's exactly the same as the SC-E7000/SC-EM800 clamp. So I ended up with a very expensive 31.8 clamp :)
This just helped me, thanks! My Rise came today and I discovered the clamp issue when installing my riser bars. I found exactly one clamp with those part numbers, on ebay, and hit buy it now quick.
Thanks!
Still have the 35mm clamp - you’ve got a buyer if you do.
    677K
