Richridesmtb
I had my left side crank come loose this morning on my Rise. It looks to be updated, i.e. without the seal and loctite applied.
Best to watch out for it. Anyone else had this issue on a recently delivered Rise?
This is a well known problem (search the threads), mine fell off four times before I found the solution:View attachment 83170View attachment 83171
apply loctite medium grip to bolts and end cap,
do not use the seal, tighten the end cap to 3-4 nM or see below
tighten bolts to 14nM carefully as the bolts are quite soft alloy
I also replaced the fixing cap with an aluminium one from Amazon and tightened to 3-4Nm.
I then had no further problems.
I'm going on 16 months with my M10 and I've never had a problem with cranks coming loose either before or after I did the service update. Odd how some have the issue and others don't.
Yep..saw that today. For those that cannot be bothered to read the full article I think the bottom line is that Shimano state the EP8 spigot is only ISO and EN tested with Shimano cranks...and that is therefore all they recommend to fit. Whilst some here have experienced the e13 cranks coming loose, the article details instances when the spigot has snapped off when fitted with non Shimano cranks, but no recorded instances of that happening if fitted with Shimano cranks. The telltale sign of impending breakage is a hair line crack emanating from the hole drilled in the spigot ( that hole used for a locator with Shimano cranks I believe but not used by some 3rd party cranks.)Interesting article from Bike Radar.
Shimano EP8 motor bottom bracket spindle failures caused by "manufacturing defects", ethirteen claims
Independent analysis alleges defects as the cause of cracked and snapped EP8 BB spindleswww.bikeradar.com
And according to the article, free of charge if you have a Commencal emtb!......................
If I had a bike with EP8 motor and non Shimano cranks I know I would be getting them changed!!
You'll buy yourself some? Don't you think Orbea should be recalling all bikes and fitting shimano cranks free of charge? It says in the article that Shimano don't recommend any after market cranks so I'm amazed Orbea are fitting E13 ones after developing a motor with ShimanoMy situation is I have the updated e13 cranks, no seal, 14nm printed on them and loctite on the preload cap. The motor has the hole in the shaft.
Will probably get some shimano cranks.
Looks to me that Shimano and e13 are blaming each other and neither wants to admit it.You'll buy yourself some? Don't you think Orbea should be recalling all bikes and fitting shimano cranks free of charge? It says in the article that Shimano don't recommend any after market cranks so I'm amazed Orbea are fitting E13 ones after developing a motor with Shimano
Yeah they're definitely blaming each other. I've always been a fan of Shimanos hollowtech system and never had a problem with it until owning a Rise. I've had the crank arm fall off and and 2 weeks back the chainring failed so I'm not feeling much love for E13 at the minuteLooks to me that Shimano and e13 are blaming each other and neither wants to admit it.
My personal view is that the design is a bit daft, pinching something onto a spline in my mind will always lead to the bolt flexing and moving.
In time this can cause the arm to slip and with the cap not doing much at 2Nm lead to failure. Normal crank arms are fixed to the drive with 40-50Nm and are done so the resist the strain and flex put upon them. These are held with 2x14 nM so half the torque.
Rise riders who have carbon e13 cranks (or should have had them but received alloy instead on LTD and TEAM) can get them replaced with Shimano under warranty from Orbea. They haven't communicated this to me and I had to contact them myself as others have done.
Commencal seem to be leading the way so Orbea it is time to step up and replace all cranks with Shimano
Have you replace it with Shimano?Yeah they're definitely blaming each other. I've always been a fan of Shimanos hollowtech system and never had a problem with it until owning a Rise. I've had the crank arm fall off and and 2 weeks back the chainring failed so I'm not feeling much love for E13 at the minute
No I haven't. The crank arms falling off was a known issue and I was sent out some new preload caps with a longer thread which have been fine since. Still waiting on news regarding the chainring and whether they'll warranty it. It's currently back with Tredz as I could not get the lock ring undone to remove the bit of chainring that's leftHave you replace it with Shimano?
I've never seen them comment on anything. I've @ them on twitter before about certain issues in the past and never had a responseDo orbea read these forums? Maybe I should contact them.
Orbea's customer service is bad imo. Especially given the premium nature of their eMTB offering.Do orbea read these forums? Maybe I should contact them.
You're having the cranks replaced? Is that from E13 to Shimano? Who initiated that change?I'm sat waiting for mine to be replaced now,outside my nearest Orbea dealer,as I bought the bike from Sigma Sports in the UK & it was way to far to go get some cranks swapped over,even this place is over an hour away.
I had to do all the leg work after receiving the letter with the bike telling me Orbea would be in touch,they never did.
I emailed them & they just passed the buck to Sigma,so I asked Sigma to send the new ones to me as I wasn't prepared to do a 350 mile round trip to sort out an issue that was none of my doing,but they wouldn't,needs to be done by an Orbea dealer.
So here I am,sat twiddling my thumbs,but at least its being sorted quickly, probably only done about 100 miles so far on the bike.
At least there was a butchers down the road that sells lovely hand made pastys.
Yeah,new shimano EM900 cranks swapped for the E thirteen alloy ones that came on the bike with the letter apologising for the fact they were not the carbon versions that the bike is specced with.You're having the cranks replaced? Is that from E13 to Shimano? Who initiated that change?
