Refilling Squirt 120ml bottles
EMTB Pro
Trying for the most boring thread of the day award ..
Recently bought one of the 500ml "Workshop" squirt bottles. The nozzle is slightly wider and with the size it's not as easy to delicately apply a tiny amount of lube. The 120ml bottles appear to be completely sealed, but if you get some pliers you can actually remove the nozzle section and refill them :
Use a piece of tubing attached to each nozzle? Probably won't work.
edit. I completely missed the point of your post😆
Lubrifiant is a nice word. Up there with sparadrap, which I imagine you are familiar with.
It's always about sex with you isn't it @apac - you're almost as bad as that Zimmer chap.
I have the 120ml bottle and the nozzle pulls out of the bottle.i do exactly the same,refilling the 120ml from a large bottle
'How to breed with small rodents' thread?
Possibly. Due to popular demand, concerns about same (species) sex - due to covid, the general devolution of any morals we may of ever had being thrown our way by the present political "parties/parties" ? - maybe that needs generally just changing ? and obviously the daily requests from @BAMBAMODA who has been known to find himself unloved by the fairer sex for several minutes here and there - whilst still noticing many attractive rodents nearby.
Squeeze a small amount of the lube from the big bottle into a small container such as a plastic bottle top, squeeze some air out of the small bottle (with its top removed) then suck up the lube from the container. Repeat as necessary.
You missed putting the top back on the small container before sucking up the lube.
That could have confused a stupid person and Zim.
Do the same with Stan’s large and small bottles you just need to unthread the caps. No tools to harm during this action.
No I didn't.
If you put the cap back on first it will be much harder for the fluid to get sucked up as the hole will be partly obstructed.
When you next buy a multi pack of crisps don't throw away the empty packets.
Instead buy a huge bag of Lays crisps and decant the contents equally among them.
It’s completely pointless to save so little with it.
Eg. in the Bike-Discount.de the Squirt SQUIRT E-Bike Chain Wax 500ml is € 9.00 / 100 Milliliter and Squirt SQUIRT E-Bike Chain Wax 120ml is € 9.16 / 100 Milliliter :LOL:
In addition, the Squirt SQUIRT E-Bike Chain Wax 500ml is a constant shortage. :confused:
The empty bottle can be recycled. Just throw it in the recycling bin.
Plus, when I did the same after the 3rd time, the 120ml bottle was very worn out. :(
