Help with micro spline freehub
Seabird55
Vancouver
i'm putting together a 2nd wheelset for commuting and was able to find a 2nd hand set of Bontranger line comp 30 wheels (same as the ones on my 2021 Rail 7) however it did not come with a micro spline freehub.
- will any micro spline freehub work?
- if i go with the original bontranger micro spline...which one do i need (there are several on the Trek site)
thanks!
I wouldn't want microspline for commuting.
HG offers far cheaper cassettes with more suitable ratios that are far more durable.
But that won't help you too much if you're running 12 speed.
So on answer to your query. Yes in regards to fitting microspline cassettes all microspline Freehubs are the same. You simply need the correct one to fit your specific rear hub. (hence different available options for Bontrager hubs)
    675K
