I have a 2020 Trance. Different to yours where the ride control is. I find that mine misbehaves if you get the electrics wet while washing after a ride. If mine gets too wet when I turn the bike off it immediately turns back on again. Your either wait for it to dry out or pull the battery.First problem on my Reign e+ 2.
It won't turn off. I have to pull the battery to shut it down. I'm going to my lbs where I bought it from to get it sorted. I have attached a video of the problem.
Let us know what the diagnosis is, hope it’s not seriousI have been riding very muddy conditions. Only done 2 rides covering about 20 miles. Hosed the bike down twice with hose on sprinkler setting and low pressure. I wouldn't say there is excessive water behind the battery cover but there is sign of some water spray.
Dropped the bike off to get it looked at under warranty today.
Hi, I have the E + 0 no problem with the water at least until now, yesterday I also washed it with the pressure washer, I just put a piece of tape on the hole to unscrew the batteryOut of interest what kind of weather/ conditions have you been riding in? Have you had excessive water ingress behind the battery cover etc? Watching with interest as my E+0 should arrive soon and I’m eagerly looking out for 2022 water related issues
.........more likely push any water further into components!!Will have to keep an eye on mine, have the same bike and have been riding muddy conditions. After I've washed the bike down and dried it, I've been using something a bit like this to blast the water out of area's, works a treat. https://www.amazon.co.uk/Display4top-2800W-power-levelless-dehumidifier/dp/B07R4XJJ91/ref=mp_s_a_1_3?keywords=dog+hair+dryer&qid=1640904307&sr=8-3
This was my concern in another thread, the controller should be seated above the frame with a seal below it no way is it going to keep water out as it is. I’ve half thought of invisiframing over it when the frame gets doneIt is poor design. They try to seal the button relying on the internal face of the aluminum tube, that face likely does not completely replicate the sealing face of the button and forms some gaps water can get in. They also try to seal pretty big surface probably fastenings this button in a few places and the sealing load is not distributed evenly so agan there are gaps for water.
There is an small 2mm? screw underneath the rubber part.There are no visisble fixings on that switch/display so does anyone know how it is held in place and how to remove it? On the gen 2 Levo it had one small allen bolt at the top whilst the bottom just hooked into a spring clip. The Giant one has no allen bolt visible so I assume it is just a spring clip on either side and push in......similarly just lever out? It needs to be removed from the top tube to determine how best to seal it.
Pending finding out how to remove it I would either push some grease around the perimeter of the switch or clingfilm it!
Why didn’t the shop run a full test before giving it back to you?! And did they say it was a water ingress issue? Very worrying if that’s the case as 90% of my riding is on sodden conditionsJust an update on this. The bike shop fixed the not powering down issue. Now it has a new fault where intermittently when I power up the bike the display will fully illuminate both rows of lights and no motor assistance is available. It will stay like this until I pull the battery. So it's back in the bike shop.
As per the TCU on a Levo I doubt it would get any water ingress whilst riding since the rubber skirt provides decent sealing for water from above. It will more likey get wet from a sideways flow of water as in washing with a hose.............or from condensation inside the frame most likely again caused by using hot water on a cold frame to wash it etc. Either way wrapping it is the answer.Why didn’t the shop run a full test before giving it back to you?! And did they say it was a water ingress issue? Very worrying if that’s the case as 90% of my riding is on sodden conditions![]()
Well it’s not going to stop me jet washing mine, if it dies it dies.. flex that warrantyAs per the TCU on a Levo I doubt it would get any water ingress whilst riding since the rubber skirt provides decent sealing for water from above. It will more likey get wet from a sideways flow of water as in washing with a hose.............or from condensation inside the frame most likely again caused by using hot water on a cold frame to wash it etc. Either way wrapping it is the answer.
I'm kinda with you on this, except that I wash mine occasionally because it's a good way to inspect things at the same time. It's only a gentle shower hose and sponge job though, with a bit of cleaner on the drivetrain to shift the oily muck before a re-lube after drying.21 years without washing a bike, i just wipe off the excess.
I save time
I save issues
35 years jet washing, drying and re-lubing my bikes with no issues, including a gaggle of ebikes. Mud is scourge and should be left in the forests lol. Next you have a garage full, car full, house full and my OCD just couldn’t handle that!I'm kinda with you on this, except that I wash mine occasionally because it's a good way to inspect things at the same time. It's only a gentle shower hose and sponge job though, with a bit of cleaner on the drivetrain to shift the oily muck before a re-lube after drying.
I NEVER jet wash them though; a jet wash is for cleaning moss off the patio floor and nothing else.
I brought my kids up on a farm and we all had recreational quad bikes for fun times. My eldest son was very proud of his YFZ450 and he kept it mint, cleaning it after every ride.
I had to fix more problems and replace more bearings on that quad than all the others combined, and at one point we had 14 of them, including the aggri. ones. Jet wash lesson learned.
Jet washing is insane and no one does it. Even on a normal bike, motorbike or a car it will strip grease and is disastrously bad for brakes.
