Other Any news on 2022 Levo Alloy models being released.
They are alive and in some shops already. Release date 14th December.
you can find the specs on line already if you search.
500w battery and 29 front and rear, does that indicate it’s just a 2.2 motor change and paint only no geo change for alloys?
Specialized M2-500, integrated battery w/rock guard, 500Wh
MOTOR
Specialized Turbo Full Power System 2.2 Motor
CAMBIO
SRAM NX Eagle, 12-speed
MANDOS DE CAMBIO
SRAM NX Eagle, single-click lever
PLATOS
SRAM X-Sync Eagle, 104BCD, 32T, steel
CASETE
SRAM NX Eagle PG-1230, 12-speed, 11-50t
CADENA
HORQUILLA
Rockshox 35 Silver TK, 160mm travel TurnKey damper
CUADRO
Specialized M5 Premium Aluminum
FRENOS
SRAM Guide RE, 4-piston caliper
AMORTIGUADOR
RockShox Deluxe
LLANTAS:
Specialized 29, hookless alloy, 30mm inner width, tubeless ready
I saw the comp carbon tonight in Switzerland, mine arrives in 2 weeks. The Alloy from what I understand is the same as 2021 and a 29er and doesn't come with new display. Chf9100 for carbon and alloy about 100 more than 2021. If you want a 2022 you have to be quick as there is still major shortages across the whole range.
More info now appearing
The all-new Levo delivers the unbelievable power to ride more trails through an unequaled combination of ride quality, usable power, and ride anywhere range. It’s the distillation, application, and amplification of a 40-year obsession with creating the world’s best riding mountain bikes. Since its introduction, Levo has set the bar every other e-MTB aims for, and the new Levo raises that bar again.
It starts with our Turbo Full Power 2.2 motor and MasterMind Turbo Control Unit (TCU), which provide Levo with a smooth and seamless amplification of your efforts—4x you power that lets you choose where to ride, and when you want to do it. Levo also shatters limitations when it comes to range, amplifying your effort for up to five hours of trail time. Now you can ride farther, and explore more, than ever before. And the optimized chassis boasts 150mm of custom-tuned rear suspension and adjustable geometry that delivers a stable and natural ride like no other. Because at the end of the day, it’s the ride that matters. Believe it.
The Turbo Levo pairs our all-new M5 alloy chassis and the smoothest and most powerful motor on the market with the most value-packed drivetrain, suspension, and brake components available. The result is a bike that puts plenty of high-dollar e-MTBs to shame.
  • Levo’s fully integrated Turbo Full Power 2.2 motor, 500Wh battery, and advanced MasterMind Turbo Control Unit deliver category-leading 90 Nm of torque and 565 watts of power for up to five hours of ride time, empowering you to ride farther and faster than ever before.
  • The MasterMind Turbo Control Unit is your information hub with customizable display fields, including the exact percentage of battery level, and it features our all-new MicroTune function to adjust power delivery in 10% increments, so you get exactly the support you need to experience precisely the ride you want.
  • A dedicated mixed-wheel size design with a 27.5” wheel in the back and 29” up front delivers a nimble ride that carves circles around other full-power e-MTBs. A generous cockpit centers you on the bike, optimizing traction and corner control. The low bottom bracket, slack headtube angle and reduced fork offset keep things stable in the rough.
  • Levo offers two distinct geometry settings, allowing you to easily dial-in its performance for any riding style and any terrain. Bottom bracket height can be fine-tuned up or down by 7mm.
  • Levo’s 150mm of rear travel is supple on small bumps, devours square-edged hits without a twitch, eats massive G-outs for breakfast, yet still offers amazing pedal response and delivers your power to the ground with total efficiency.
  • The Levo’s S-Sizing is based on what matters—rider size and style, not inseam. Six sizes, all with similar headtube lengths and standover, allow you to choose the size that best suits your individual style. Smaller S-Size numbers are going to be nimble and more flickable, while bigger S-Sizes deliver more stability and a roomier ride.
SPECS
  • Seat Binder - Alloy, 38.6
  • Frame - Specialized M5 premium alloy, BB height adjust, S-Sizing, internal cable routing, 150mm travel, 148mm spacing
  • Fork - RockShox 35 Silver, 35mm stanchion, Turnkey damper, S1: 150mm travel, S2-S6: 160mm travel
  • Rear Shock - RockShox Deluxe Select R, rebound adjust, S1: 52.5x210mm, S2-S6: 55x210mm
  • Stem - Alloy Trail Stem, 35mm bar bore
  • Handlebars - Specialized, 6061 alloy, 6-degree upsweep, 8-degree backsweep, 30mm rise, 780mm width
  • Tape - Specialized Trail Grips
  • Saddle - Body Geometry Bridge Saddle, steel rails
  • SeatPost - TranzX dropper, 34.9mm, S1: 100mm, S2: 125mm, S3: 150mm. S4-S5: 170mm, S6- 200mm
  • Front Brake - SRAM Guide RE, S1-S3: 200mm, S4-S6: 220mm
  • Rear Brake - SRAM Guide RE, 200mm
  • Rear Derailleur - SRAM SX Eagle, 12-speed
  • Cassette - SRAM NX Eagle PG-1230, 12-speed, 11-50t
  • Chain - SRAM NX Eagle, 12-speed
  • Shift Levers - SRAM SL SX Eagle, 12-speed
  • Crankset - Praxis forged M30, custom offset, 160mm
  • Chainrings - SRAM X-Sync Eagle, 104 BCD, 32T, steel
  • Rims - Specialized 29, hookless alloy, 30mm inner width, tubeless ready
  • Front Hub - Alloy, sealed cartridge bearings, 15x110mm thru-axle, 32h
  • Rear Hub - Alloy, sealed cartridge bearings, 12x148mm thru-axle, 32h
  • Spokes - DT Swiss Industry
  • Inner Tubes - Standard, Presta Valve
  • Front Tire - Butcher, GRID TRAIL casing, GRIPTON® T9 compound, 2Bliss Ready, 29x2.6"
  • Rear Tire - Eliminator, GRID TRAIL casing, GRIPTON® T7 compound, 2Bliss Ready, 27.5x2.6"
  • Motor - Specialized Turbo Full Power System 2.2 Motor
  • UI/Remote - Specialized TCU, 10-LED State of charge, 3-LED Ride Mode display, ANT+/Bluetooth®, w/Handlebar remote
  • Charger - Custom charger, 42V4A w/ Rosenberger plug
  • Battery - SPECIALIZED M3-500A, INTEGRATED BATTERY, 500WH, SBC-B21
  • Wiring Harness - Custom Specialized wiring harness
GEOMETRY
Min Seatpost Insertion808080808080
Max Seatpost Insertion 210220240255275295
Seat Tube Angle7877.276.776.276.276.2
Seat Tube Length380390405425445465
Bike Standover Height752776783787788790
Wheelbase 1179 1200 1225 1255 1284 1318
Chainstay Length442442442442442442
Front Center738760784814843878
Fork Rake/Offset444444444444
Fork Length (full)557567567567567567
Trail130130130130130130
BB Drop252727272727
BB Height352350350350350350
Headtube Angle64.564.564.564.564.564.5
Headtube Length105105115125135145
Reach412432452477502532
Stack605617626635644653
Seatpost Length100125150170170200
Saddle Width155155143143143143
Stem Length404050505050
Handlebar Width780780780780780780
Crank Length160160160160160160
SizeS1S2S3S4S5S6
Today I picked up a Turbo Levo Comp 2022 (Alloy). Models will be released/publish around December 16th.
Mullet, Eagle GX, SDRAM Code R, 200mm rotor, Fox 36, Fox Float X.
No display though.... (old TCU)
I'll upload pictures tomorrow.
Sydney, Australia
Sydney, Australia
"Mean while, a Little boy waits . . "
Is it tomorrow yet?
yes just seen 2022 Levo in alloy color gloss black it was the alloy comp model same everything as in geo but not with the new TCU its the same as last years.
Was the colour scheme called black/dove grey/black?
Is that the Sage colour?
maybe... to be honest i didnt even bother about colour when i ordered back in May. I asked for grey colour scheme or whatever similar.
I also forgot to mention that the bike comes with the adjustable headset cup which gives -1/+1 degree angle.
Rode it today and I absolute loved it. So much power, compared to 2021 Hard Tail, really smooth riding. Beast climber.
This alloy is exciting. I have a deposit on a US 21 kenevo for a great deal and if this is coming to the US I may change my order.....I'm guessing will be same price factoring in the discount on the kenevo
Thanks for the clarification. Was just curious as a couple of the posts on this thread mention 500wh in quoted specs.
The 700Wh is the Comp. So if there are specs with a 500Wh battery it seems that there is actually a base model arriving...
Gents,
what is your opinion, please? It is good deal to buy cheeper Gen.2 (Turbo Levo) or Gen. 3 (price difference is ±600EUR) From my point of view there is difference in geo and motor. (and I don't want to ride downhills, just trek). Many thanks
Gents,
There is no difference in motor apart from a number. From a re-sale perspective I would go with the Gen3. If you are not bothered about price then go with the Gen2 as the geo will be very slightly better for your type of riding.
    670K
