New EMTB - SCOAR 4060Z
EMTB Pro
Looks interesting, a side brand out of BMC.
720wh battery, EP8, tow versions based off same frame 140/150mm and a 160/170.
Prizing looks very competitive too
First review, 22.6kg with a 720wh battery, and a burly build is impressive
If that weight is legit than that's extremely impressive.
XT spec, aluminium wheels, big battery, aluminium finishing kit... and 22.6 KG
Would be nice to see them do a longer travel version with a slacker HA.
Will be interesting to see when they can deliver the bikes
The geometry on the Enduro 29" is very very impressive. They've managed 29/29 with a 435mm chain stay and 160mm rear travel. And very very competitively priced.
I enquired about availability of these a while ago, they didn't have any plans to sell to the UK at that time... :(
There is a bike shop in Sallanches close to Morzine that will sell Scor
I am already on the case though some Swiss connections
Hello from Barcelona.
Scor does not have any distributor in Spain and I bought an LT model in Italy after writting an email to every single bike shop that sells Scor in Europe. The bike is already in Spain but I will receive it next moday...I hope so.
Intersting bike. My question is pointed to the non drive side. The frame seems to cover the motor accessory connections. So adding the light or changing the speed sensor or display cable requires you to drop the motor.
Also I wonder about that seat tube, how long dropper will that fit? Why not cut the seat post lower over the top tube? 160mm dropper in size L is too short imo.
What bottle holder you have there?
I think thats the Canyon Eject Hydration System
The maximum insert of the seatpost into the seat tube is 250mm.
The dropper in L size is 170mm travel. My intention is to install a OneUp of 210mm travel, if I'm not wrong I will be able to drop the seat about 3cm lower than now.
Nothing to say about adding lights or changing speed sensor.
