Bike thief cuts through lock of £3k electric bike at shopping centre
The thief was seen using the battery-powered tool on the bike outside Surrey Quays shopping centre in Rotherhithe, south east London, at around 1.30pm on Saturday.
Cowards. How could you let that happen and not at least call the cops and follow them, if not kicking their scumbag asses?
yeah I’m sure you would do that pal, he had a angle grinder which he most likely would have used on who ever challenged him. We are in the UK not the US of A so couldn’t put a cap in his ass.
On a serious note, it’s London. You could be getting stabbed or kicked to death and people would carry on as normal.
I'd sure as hell call the cops and follow them if I could. BTW, not everyone here carries a gun. Shocking, I know.
We had a similar but even worse incident recently where a woman was raped on a train and no one intervened - and apparently a couple people actually filmed it with their phones. Just horrifying.
Can’t quite work out what lock it is. Would that handheld thing get through an ABUS Granit?
There is still Citizen's ArrestI have a corded angle grinder (i.e. something much stronger than any battery-powered unit) that I got to refinish my cement basement floor so I could add some flooring to it. It is not a real threat unless you are inanimate. A power drill is more threatening. A hammer or a chisel is much more threatening.
Only in Texas could you use a weapon to defend your property, and even that isn't absolute.
The problem anywhere is that a smart thief would just ignore you if you tried to stop him. If you resort to physical force, you can be provoked into a situation where they can accuse you of assault and battery, which to a by-the-letter cop is considered a more serious offense than the accused vandalism/theft. In any case, the cop would have to put the accusation on his report, which can be a basis for a civil suit if the "accused" thief can find another professional scumbag to attest to his lasting physical harm and mental anguish.
So, the only way to deal with the situation is to dispose of the bike thief discreetly and completely.
(I'm obviously not being serious on that last part.)
Yes.
Only something like this is resistant to an angle grinder.
Watch Us Cut This “Angle Grinder-Proof” Bike Lock
The Altor SAF Lock eventually succumbed to the grinder, but it took more than hour of cutting.www.bicycling.com
You've obviously never seen what an angle grinder does to flesh. As well as efficiently removing flesh, it burns and leaves behind fragments of grinding disc. Removing those fragments from burnt flesh is NOT fun.
Have you used an angle grinder???
An angle grinder is only going to do that to flesh if the flesh is sitting still and not trying to avoid it. Again, inanimate. Or if the wielder uses his one free hand to hold you to the grinder. A grinder is not a chainsaw (or even a circular saw) and does not have a self-feeding action. If swung dynamically, it is no worse than a knife, and one that can't stab at that. Wielded with one hand, it is basically a club. Yes, you might suffer a first wound. But it's a pretty shitty weapon that can neither incapacitate, nor will likely get a second wound. At that point it'll be ground-fighting.
I strongly suggest you never test those theories.
Again, have you actually used an angle grinder?
It does not do as much as you think without continuous application of force against the thing it is working on. I only wished it did; it would have saved us a hell of a lot of work.
I use an angle grinder a fair bit and it is one of the most dangerous hand held power tools in my extensive arsenalAgain, have you actually used an angle grinder?
you're an idiot and should shut up now.Again, have you actually used an angle grinder?
bloody idiotAn angle grinder is only going to do that to flesh if the flesh is sitting still and not trying to avoid it.
is this taken from your extensive experiences of grinder kata's?But it's a pretty shitty weapon that can neither incapacitate, nor will likely get a second wound. At that point it'll be ground-fighting.
Batterie hanheld tools can cut anything. If they create one lock that can resist, still the scum can leave a top carbon fiber frame cut to pieces aside it waiting for the smart owner to return.
Heres an injury from a forum buddy on another bike forum. Result of the grinder jumping and briefly coming into contact with his hand. I know he wont mind me reposting it, he feels its a bit of a battle scar
This is obviously just impacting bare skin, but were the tool to get get caught up in a jumper or sleeve it would very very quickly wrap itself up and bury in deep. Doesnt actually bear thinking about. But pretty much one of the reasons when using machinery or power tools like this you wear your sleeves above the elbow.
I’ll admit to being corrected. I’ve only used small angle grinders, and although aware of the dangers of shattering the grinding disc, I didn’t (and still don’t) find the dangers of that relevant in the original context of getting into a scuffle against a bike thief equipped with a battery-operated angle grinder (which typically have 4.5” discs). But I guess the lack of tight phrasing has brought out the angle grinder hardmen.
On a separate note, I do find it interesting the how of making a point when people are given the opportunity to do so. If not revealing of character, it certainly is so of attitudes.
Well done the voice of reasonIt's a toxic mix. First we're all angry about bikes being stolen. Then it heats as the 'smart' people and the 'tough' guys disagree over response. Then people call out other people's experience of power tools. If this was 12.30am down the kebab house it would've been a brawl.
