Can you build your own battery for the E10 ?
Hello ,Nice To hear but hard to believe from a bafang M600 .Are we talking about the same motor ? I got max 70km(1 batt) on flat hardend roads with zero hm .on a dengfu batt 840Wh
1.4%/km seems hard cycling. i have an average of about 1.25%/km for about 250m elevation gained on average. 90% on PAS1/9
Dont exactly what you mean with the nummers above ...but yes PAS1 is the most. (even 95%) i use also ...more than assist enough (-: but then again 4-500hm means minus at least 10km in lenght.
I did the 70km also on one battery. The e05 Dengfu with m600. And I did that a few times by now. You just don’t use throttle and never go past lowest pas level. Ofcourse it depends on many other factors like your own weight, tyres etc etc. In this case it’s a trail bike.
Looks like battery consumption of around 1.42% per km is about what most people are getting. Which firmware's are most of you using?
My numbers were on the 46.6 software 48v. I upgraded to 46.7 recently but haven’t got results on maximum range yet. Continuous assist on pas 1 is lower on the 46.7 but the first ramp up when starting with pedalling is way higher then on the 46.7
i am on 46.7 as well, and i am hoping someone can chime in on the bfang 14.6 firmware compared to the 46.7 in terms of torque level at PAS 1 and battery consumption.
Hello everyone. i would love to have a battery of about 400wh. for short fast rides. is there to buy such a battery that is in the original case for e10? or is there somewhere to buy such a case? thank you
MYR 729.69 40%OFF | Hidden Ebike Battery 48V 17.5Ah 17Ah 14.5Ah 13Ah 36V 15Ah 18Ah 19.2Ah 20ah 21Ah City Bike Fat Bike Off Road Bike Battery
you can request empty case from this seller
There is space with the 14s3P 21700 battery I built at either end and I think with careful battery construction and layout it could be possible to build a 13S4P battery but it would be very tight I would suspect as the frame is designed with 18650 batteries in mind.
A 14S3P Samsung 21700 50E battery will give you 780W\h’s
A 13S4P Samsung 21700 50E battery will give you 960W\h’s
Is it worth the cost and development for just 18% of additional battery ?
I’m only using about 550W/h’s on 1K of climb over 50K of quite knarly and slow off road, and would suspect that if I backed off a bit on power and had more open terrain, 100km would be possible on the 1 battery ?
I would love to see a video of how someone would build one of these batteries to see exactly what is involved. Do you know what the cost would be aproximately to build a 13S4P Samsung 21700 50E battery that will give you 960W\h’s?
Also interrested ...(-: This should push up the range a bit !
greeting. here is the first picture of the 13s4p battery, 52 pcs samsung 50g cells smart bms 30A. the battery should arrive next week.
Looking good. I have a few questions for you.
1. How much did it cost for all the materials?
2. Would you be able to post a list of materials used and possibly links of where you got it?
3. Does it fit in the stock battery case?
I know, I know, sooo many questions. Thanks so much.
cells are 21700 20ah. I didn't do the battery myself. I ordered from a company. the battery cost me less with assemble in that company than if I ordered cells, bms .... and everything I needed. and then there is still no guarantee. this is how I have a guarantee. I send you an email in the inbox so ask everything directly.
does not fit into the original housing should be adjusted.
Great result! Would You mind to PM the contact to that company, so I could ask them to build a battery for me as well? They are located in Croatia? Thanks mate!
hi, changing the original battery for another larger battery is plug ang play?
Has anyone opened up the E10 battery pack to see how the wirings are connected? I have the rough sketch of the battery connector on the frame.
Hello.
Can someone put an image of how the integrated battery cells are arranged in the frame?
I am building an E22 and I have ordered the empty battery box to build the battery myself.
Dengfu-E10-bike-battery-empty-case-SUONI-SSE-103-inner-tube-boxes-for-65-Pcs-18650.jpg_220x220xz.jpg
The battery box is the same as the E10 frame.
I don't know if I explain myself well...I need to see the layout of the cells so that a configuration of 13s5p or 14s4p can fit in the box.
Hello.
Can You please tell where You bought the empty battery boxes? Do You have the frame mounts for the battery available? Thanks mate!
Hello.
I don't have a picture to share but I do know that the cells are placed inline with the length of the case.
I have ordered the frame with the frame mounts for the battery and the empty battery box In Alibaba.
I hope to receive it!!
It's my first purchase on Alibaba and I'm a little suspicious.
It is also possible to buy the battery box alone, on Aliexpres:
Not sure why you want battery boxes, if you want to build / have built a custom battery then why build it into an existing box which already is available as a fully built up battery. If you want less Wh such as 13S2P then the M600 has a well known connector to simply plug into, if you want more Wh then your extra cells are not going to fit into the existing format box, Bafang would have done that.
Because I enjoy building my batteries and I save at least 200 Euros on a 840Wh Battery made with quality cells.
I enjoy the constructive process of a bike and the fact of riding a bike.
This makes total sense. I went down the stock case route recently. The case, while convenient that it fits into the stock connectors, restricts the Ah's possible as well as BMS size and cell size. Being able to group the cells perpendicular to the down tube as shown above rather than parallel will allow for the use of more and also larger format cells and a bigger BMS in the stock cavity with the stock cover plate. If a deeper cover plate was made then an even larger Ah battery is possible. As is the largest possible would perhaps be 21ah non cased.
Hi Thaeber I have one empty box if you are interested .I bought it with the frame directly from Dengfu.But my friend who i am building the bike for, decided that he wants a battery with warranty and we bought a battery from Tossa.So if you are interested i can sell it to you for 50 Euro + shipping which is another 10 euro or so .
This offer is for everyone in Europe ;)
Greets
Sava
    Join 43,230
