There are no stupid questions...but...
MOTO13
Elkhorn, Wi
I am going to test this theory. Here's my stupid question...
Has anyone put a 31.8mm bar on a bike with a 35mm stem without installing a different stem? I have a set of 31.8mm carbon bars I want to put on a bike that has a 35mm stem. I figured maybe wrapping the bar in silicone tape or even cutting some plastic tubing and putting this around the bar to make it fit in the 35mm stem. I ride single track with very few if any jumps or drops. Ok...how friggin dumb am I? Let it rip.
Phenomenally. Hope that helps. 👍
Have you got a good dental plan? Stems are a lot cheaper than teeth.
A split aluminium sleeve, machined to tight tolerances might be ok, but will likely cost more than a new stem.
Yeah...I figured as much. I had braces as a kid, plus I'm pretty. Rather not screw this up...lol. I am just going to buy 35mm bars and be done with it. Looking for more rise than the stockers. I had a spare carbon bar, but it fits my Trek, not Husky.
Thanks for chiming in and saving my face.
I’ve used quality shims in seatposts. But unsure if I would trust them in a bar situation…
Don’t use plastic or silicone!!!
Change of stem is a cheap option, does a friend have one with a 31.8mm clamp you can borrow to try?
If not some shims like this are available online:
I just ordered new bars (35mm) from Amazon. I want to get a new stem also, just not sure what size my Husky has. I think it's 40mm.
    Join 42,937
