• Warning!!
    UK Pedelec Law
    Worldwide Laws
Shimano Steps E8000 software tuning
Iain at the back
65
76
Labamo
I have been struggling to change the derailleur type of my bike as when you add a Di2 rear mech you just get a W032 error and the solution in the Shimano issued error codes is “replace the original derailleur” yeah thanks.
I stumbled onto the Emax software that allows you to alter many things on the E8000 without chopping wires and sensors around.
eMax - english
I hvent done any tuning on my bike as it is not something I want to do, but it has enabled me to change the derailleur type to electronic. If however you want to increase the motor cutoff and do many many other things, I would seriously look at this. The level of support I have had from the people at Emax is truly outstanding given that I am using the free version of the software and it was my computer causing the issues I had.
You will also see that there is a version call Freemax that allows you to correct the circumference of the wheels and that could increase the motor cutoff but the speed indicated on the display would be wrong. The Emax software would allow you to increase the motor cutoff but with the speed indicated correctly on the display, but this requires a license key that you need to purchase. You will also need the Shimano PCE1 to link the computer to the bike, but if you want a solution without having a dongle plugged in, this could be the answer.
Tori
282
423
My partner just purchased a PCE-1 interface with Emax software to de-restrict her Merida E160. She had to downgrade to an earlier version of firmware to remove the speed restriction. We have both just been out for a ride on her bike and it's amazing, pedal power up to 50kmph sustained on flat terrain. Limited by the gearing I think - the limit of support cuts out at 60kmph.
The hardware and software cost to do this was $400 AUD.
She won't be running it at full de-restriction all the time, as she realises it defeats the purpose of the bike for her and that it will chew battery too quickly, but she wants to run it at a slightly higher motor cut out of 30kmph (here in Aus we are limited to 25kmph).
rm00214
Hi Tori .. I own the same bike too and looking to do the software de-restriction. But how did you manage to get it done for $400
Could you please suggest me any websites where did you get them from.? I am from Australia too
tebapk2
ES
Any news about limit shimano steps?
