Levo Gen 2 Turbo Levo - SRAM HS2 220mm rotor on rear, does it look ok for you?
bPlaTyPuS
Switzerland
Hi!
I ordered the new SRAM 220mm HS2 rotor to put on my Turbo Levo 2019 carbon. It's the first time I'm changing a rotor and due to the size increment (200mm -> 220mm), I swapped the +20mm adapter to +40mm. But those really don't have the same shape... so I'm wondering if my mounting is OK or not...
What do you think? does it look safe :unsure:? (with the +20mm adapter, the screws were going directly into the frame....)
Here are some pics (don't worry about the left screw, I have to find one which has the right size!) :
I know some of you will tell me that it's better to mount the bigger rotor in the front.... but I don't agree with this! I would say this is correct when you ride on 'normal' roads... but on long steep descents done on unstable surface, I need my rear brake to control the descent!
So if this works, I'll have 200mm front and 220mm rear ?. (+ also installed ceramic pads.... instead of the originals which were be sintered I think)
Thanks for your help!
Except front bolt being too long (or not yet tightened?) it is exactly as it should be.
My OCD wouldn't be ok with larger rear rotor ?
Looks good to me. I run 220's front and rear on my Levo
Did you use 2 adapters for the front?? Because there's no SRAM 60mm adapter (or I didn't see it?)
edit: or maybe you don't have the same fork as me (fox34 -> didn't change it)
I've got at least 1000 miles with lots of heavy braking on my similar Magura setup. No issues.
Ignore the numbers, I created this pic for another post months ago.
Edit: Someone is going to ask about this. My pad scuff marks are exactly where they should be on the rotor. The pad to disk alignment would be screwed up if I used bevel washers under the adapter or under the caliper.
Fox 34 has PM 6" (160mm direkt mount)
I guess they don't recommend to go for a rotor larger than 200/203mm.
I have a RockShox Pike upfront - used one adapter
Hi!
This looks smart. I'm setting mine up. I have the rotor fitted but need to know the details for the correct post mount please. I did get one which was 40mm IS but this was incompatible. Can anyone help..?
It's the top one on the picture.
Yes on front, but on the back I dont see point for 220mm... 220mm rotor gives you 10% more breaking torque with same pull on the lever, bigger rotor also disapates heat better.
but.. isn't that just urban myth matey ?
This doesn't convince me. 220mm on the back also looks silly.
Silly me. Apologies if you thought that I was attempting to convince you of anything.
There's no accounting for taste they say. Thanks again for the tip. Have a great weekend. (y)
Why does the test not convince you of the validity of a larger rear rotor?
I run 220 front and rear and it is a great combo. In relation to not looking good, that's a personal thing but most ebikes don't look that great anyway imo.
    676K
