I have a bad back so Ireally need a stand to try and look after my sons bike.
I didn't think the seat post would be a great idea.Lifting an eMTB onto a stand is awkward and might actually aggravate your back more. Also, with some dropper posts, use of a seatpost clamp-style stand isn't always a great idea. Good luck and let us know what you find that works for you!
I would almost prefer just an arm. Are there maintenance stands available that will safely hold an ebike and not twist, break or topple over that cost less than £200-£300?
Do you hold the bike by the seat post?I have a Bike Hand Repair Stand that works fine. I chose it years ago because it was inexpensive and I wasn't sure I needed one. It turns out that I really like having a stand, even for such mundane chores as cleaning the bike. The one I have costs 120USD and is rated at 55 pounds. I see that they have another model now, rated at 100 pounds, for 170USD. It looks mostly the same, with the exception that the clamping head appears to be made of aluminum.
The Bike Hand is a knock-off of the Park Tool Stand. The Park Tool is more expensive, but appears to be more nicely made. If I was to do it all over again, I might go with the Park Tool. But if there are budgetary concerns or you're not sure, then go with the Bike Hand Ebike version. Also, I always rotate the head horizontally and clamp on the frame.
There are other suppliers that may do so. Let Google be your friend.Unfortunately they will not ship to Italy at the moment.
I thought of making something up myself. I have lots of space so permanently mounted.I bought a Park tool home mechanic work stand for £130. I wasn’t happy with clamping to the seat post so I cobbled something together on the CNC machine to hold it by the frame.
View attachment 69204View attachment 69205View attachment 69205View attachment 69206
That one is very nice and looks absolutely ideal for our heavy ebikes, but £330 is really expensive. Possibly a bit overpriced for what it is.I use one of these...Park Tool.
You can secure the fork in the clamp with the bike still on the floor then lift/lever the rest of the bike up and onto the BB rest ( for an EMTB it sits on the bottom of the motor)......no strain on the back. Whilst the Levo ( pictured) is possible to mount on a standard bike stand using the back end of the top tube, it is not possible on my Whyte E 180 RS of my wife's Cube Access......hence why I bought this type of stand.
Mounted as per the photo the only part of the bike you cannot service is the headset but the bike can be mounted with the rear wheel through axle in the clamp ( ie the other way around) if you needed to do that.
One thing I find really useful with this stand given the limited space I have in my garage, is that you can rotate the stand and therefore work on both sides of the bike without moving.
I bought the rail extender at the same time to ensure the rail was long enough for my Whyte but it is not needed for the Levo or Cube Access.
The only modification I made to the stand was to fit a rubber block between the "prongs" of the BB support.
It may be an option for you.........Park tools so not cheap!!
May be worth a try. To be honest they do not really need to be that strong because the BB/motor sits right over the main upright nd that is where most of the weight is. One thing to check is the maximum distance between the fork mount and the position where the BB/motor casing sits. On the Park Tool I have to also buy the small platform extender piece to mount my Whyte E 180 although that bike admittedly has a pretty long front centre. Another aspect to check is the BB mount. The Park tool one is designed for a normal bike BB. I used a solid rubber block wedged between the 2 "spikes" that form the BB mount so that it became a flat surface....a block of wood cut to size would do the same job. As I mentioned a bove the 2 aspecs I really like a bout the latform type design is that the bike is far more stable than on a clamp type stand and the bike can be rotated 360 degrees.That one is very nice and looks absolutely ideal for our heavy ebikes, but £330 is really expensive. Possibly a bit overpriced for what it is.
Lifeline do a similar stand for £90- I couldnt say though ifit is as strong, in truth it looks a bit flimsy, and i cant find any YT vids showing it in use with an ebike.
