Ceramic Wax Chain Lube
Tubby G
❤️‍🔥 Hot Stuff ❤️‍🔥
North Yorkshire
Last weekend I bought some Finish Line Ceramic Wax Chain Lube from a trail centre cafe as I needed some lube and that’s all they had
The lube doesn’t just drop & flow out of the bottle such as Muck Off or Peaty’s, it basically ‘ejaculates’ all over my chain, bike frame, wheels, tyres, no matter how carefully I squeeze the bottle. It leaves a right a mess, my bike looks like it’s been the centre of attention at some dogging fest in the woods
So, question. What’s the correct way to apply this lube ? I was going to use a cloth or a toothbrush and wipe / scrub it onto the chain, but thought this can’t be right
I’ve used the search function but only found someone cooking up a wax formula in a slow cooker and ultrasonically cleaning their chain ?
Ta
.............................it basically ‘ejaculates’ all over my chain, bike frame, wheels, tyres, no matter how carefully I squeeze the bottle. It leaves a right a mess, my bike looks like it’s been the centre of attention at some dogging fest in the woods.........
A very vivid description, as though you can clearly recall it to mind. :ROFLMAO:
poke the hole until it gets bigger.
Poked the hole, the lube now flows! Sometimes the most simplest of answers are the answers we are looking for. I feel daft now! I was thinking that the ceramic wax lube was much thicker than usual lube and had to be applied differently. No, it was simply the hole was blocked. Doh! Thanks
How have you found the lube? I’ve got some on order.
i hot waxed a chain for first time and had terrible drivetrain problems since, so was going to try this on top of the wax to see if it makes things a bit smoother
Hi I’ve used finish line ceramic wax fora while now and yes sometimes the hole has to be freed as when this liquid wax hits the atmosphere it hardens pretty quick especially if ur in a cold garage or outside,sometimes I squirt one into a small top of anther bottle and paint it with a small artist brush onto the rollers both sides, drivetrain runs silently with this wax
    675K
