Geedog
Hello, I have had two chainguides break, has anyone fitted a better guide or is there a good quality alternative to the e13 that comes stock? It's the trek rail 9.8xt
I've found one, it's by Reverse, steel not plastic, needs the original spacers as it comes with none. Easy enough to fit and set up.Hello, I have had two chainguides break, has anyone fitted a better guide or is there a good quality alternative to the e13 that comes stock? It's the trek rail 9.8xt
Out of curiosity....how did you break ur chain guide?Hello, I have had two chainguides break, has anyone fitted a better guide or is there a good quality alternative to the e13 that comes stock? It's the trek rail 9.8xt
I wouldn't waste your money, the Reverse is much better quality, and in stock. Tho to fit it to a trek you need the original spacers and screws. I'm keeping my 3rd e13 as a spare, just in case.My chain guide broke off very easily when chain got thrown But im still replacing with ethirteen unit for simplicity
it wasnt organic, I gave it a slight tug trying to get chain back on causing the snapAgreed, I had to wait 3 months from trek, luckily I have a mate who had taken his off, so i had his, that one broke the day the trek one arrived, which was good timing. I can't see the Reverse breaking its arm.
Did you need to remove the chainring to fit?
No.Did you need to remove the chainring to fit?
That is a stunning bit of kit. Did you sell a child?Absolute Black Super Steel chainring installed. 34t. No issues with fitment with Oneup Chain guard.View attachment 111298
I did, but you can access the holes through the chainring if you want, I take my chainring off, clean up around the bb/axle area, then there is a clean area where the chainguide goes and easier job, I dab a bit of grease on the washers, which helps keep them in place on the arm when lining it all up. Then loctite the threads on the chainring lockring and tighten up as much as needed.Did you need to remove the chainring to fit?
I will not admit to that...........That is a stunning bit of kit. Did you sell a child?
That is a thing of beautyAbsolute Black Super Steel chainring installed. 34t. No issues with fitment with Oneup Chain guard.View attachment 111298
got full install pic ?!Absolute Black Super Steel chainring installed. 34t. No issues with fitment with Oneup Chain guard.View attachment 111298
It is good.My standard chain guide broke too and currently bodged together with a larger screw! Reverse one looks good![]()
