Tubby G
❤️🔥 Hot Stuff ❤️🔥
Hot ?
I was going to reply to this with a pic of the empty box surrounded by dead bottles with the caption "It was the best case of corona ever" but my mate chucked the box on the fire pit before I had a chance...You ok bud ? Looks like Corona that !!
P.s I am an NHS key worker and although I make a semi joke regarding Corona it's not a malicious post so please don't take it to heart. If it offends anybody then please rest assure I do not take C19 lightly.
Spray the rear mech red for some balance ?Thought it was finally time to stop spending & start hitting the trails to test out the new bits & pieces.
Pleasantly surprised with the resultsView attachment 63510
stupid fat fingers - fixed nowTwice ??
Sticks of all shapes and sizes just seem to be drawn to me ..
It’s a green chain guide
I think @Pivot has some so I thought I'd give them a try. I tend to use pedals as landscaping devices, so I'm not buying some beautiful machined work of art to destroy. Think those will swap onto the Kenevo as they'll match the Yellow TTX shock.They can't really miss you with those pedals![]()
Rather the landscaping approach than the open shin surgery lol. I like those pedals though.I think @Pivot has some so I thought I'd give them a try. I tend to use pedals as landscaping devices, so I'm not buying some beautiful machined work of art to destroy. Think those will swap onto the Kenevo as they'll match the Yellow TTX shock.
Agreed !Rather the landscaping approach than the open shin surgery lol. I like those pedals though.![]()
Yeah my face off green/white were cheapo but they are really solid. I've not had a slip off since fitting. Although if and when I am sure I will lose half my leg as the pins look and feel savage. I've had a few pedal strikes and my feet stay planted regardless and they are still going strong. If you like em keep em onAgreed !
For a cheepo pair of pedals they seem fairly well put together. The shape seems good too and they concave in the middle a bit. Plus there's extra pins supplied and you can obviously take out any you don't like. No idea how they'll hold up bearing wise and they don't spin out of the box like a perpetual motion machine.
They're pretty much exactly the same size as my Raceface Chesters. The chester is slightly longer due to it's chamfered front and back edges - but the platform area is the same.Yea, mine are working very well. I like the surface-grip — my feet are firmly glued to the pedals.
The pedals didn’t spin freely out the box and I treat them with WD40 now and then. I am satisfied as long as they spin when I direct a water nozzle when I wash the bike.
They also make an x-wide version (13.5cm IIRC) which are even better for surface-grip, but I used to get too many pedal-strikes in the woods, to the point that one of my cranks came off and I had to replace a set. So I reverted to these which are larger than OEM, but not Big Bertha calibre![]()
Were you stopped near an induction loop vehicle sensor?Incidentally, how about this for a bit of tin foil hattery. The route I took today passes through a big Tesco car park. I stopped to tie my lace & when I set off again, the motor gave a 510 error. I turned it off & on again & it was fine. The motor has never given any errors before. But get this, in the past I've had several occasions in the same car park where my car wouldn't lock or unlock on the fob.
They're beaming some sort of mind control ray from the deli counter, it's the only rational answer. ???
So if we lay the trails with induction loops - is that another way to remove the assist restriction ?No idea. Weird coincidence though.
Shape wise, they're inverted with the chester having a wider front than rear and the rockbros having a wider rear than front.
