• Warning!!
    UK Pedelec Law
    Worldwide Laws
Bosch Gen 4 derestriction
so whats the best way of derestricting these???
Speedbox 3, VOLspeed V3
There are differing opinions as to whether the Bosch Dealer Software can detect tuning and it will invalidate the warranty if they can.
can power modes etc be adjusted in an app???
No.
No.
have you done your rail, if so which option did you go for???
Different bike but same motor/control
I haven’t, I just pedal harder when I need to. There are times when I’d like the limit to be higher but after having 4 of the old Bosch motors replaced under warranty I’m not prepared to risk losing my warranty even though the new motor is proving to be far more reliable.
Will try without 1st and see how i get on, my local area isn't that interesting so speed helps a little. I'd like not to use it to be fair just to increase range.
1st ride today, think i defo wanna derestrict, will i need a crank puller on the 9??
It is possible to drop the motor without removing the cranks but it's a bit unwieldy.
Simple as, 5 minute job, just remove bottom cover, instructions on Youtube, know someone who did on Rail, he can easily cruise at 50kph or 30mph.
yep did it yesterday, bash guard off, plug in and pretty much done.
I have the speedbox3 on my Bosch from new, 500km and no issues, allow the countdown to finish before powering off and jobs a good'un.
i went for the volspeed so i didn't have to wait for countdown, i know what im like. Always like to get bike cleaned and lubed immediately.
I’m also interested in derestricting mine, but I’m not sure anyone makes one that’s compatible for the new Bosch smart system AND the Bosch wheel rim/valve stem magnet sensor. Anyone know?
Unfortunately that won’t work if you have the Bosch wheel rim valve stem magnet sensor. I emailed them and they confirmed that it won’t work.
just put a magnet on the wheel spokes.
Yeah thanks, but it doesn’t work like that. My motor sensor is internal. There is no cable or wire that runs down the chainstay to a sensor on the spokes or rotor. It’s a wireless connection from the valve stem magnet to the motor.
it is a magnet it is not wireless or do you put batts in it lol
Yes, it’s a magnet. Its wireless in that there is no wire and sensor that runs from the motor to the magnet on the valve stem or down the chainstay to a magnet on the rotor or spokes. That cannot be changed to a wired system without changing the program parameters in the software which can only be done by a certified Bosch service center. So I’ll just have to wait until someone comes out with a solution to work for my setup, (2022 smart system with the Bosch wheel rim valve stem magnet). I was originally asking to see if anyone made a de-restrictor FOR MY SETUP, not to try to change it to a different sensor setup.
Eplus had some info on this a while back. They said their version for the rim magnet will include a standard speed sensor for the chain stay and some sort of insulating material that's meant to be attached to the motor, to prevent the built in sensor reading the rim magnet. Looks like it's now due in the market in September: Bosch Smart System – Speed Unlocker
Thread tidied.
This is a thread to discuss how to de-restrict in the de restriction area of the forum. Each thread has the relevant warnings about de restriction at the beginning of each thread.
De restriction techniques should not be discussed elsewhere within the forum.
Likewise, trolling the de restriction technique threads with your views and opinions on de restriction is also wasting everyone's time. If you wish to discuss the reasons why you should/shouldn't there are many existing threads on the subject.
‘We’ll after looking at their website, they mention having an application for the Bosch smart system with the “classic speed sensor” but they don’t mention anything about the wheel rim magnet version. I’ll have to contact them and see. Thanks for the info and link. 👍🏼
edit, I emailed them and they said they will have a compatible system for my setup in September! 😃👍🏼
Any updates?
So a hall sensor is in a motor? and it reads magnet's passings even from 5-10cm ?
So to those that have fitted a speedbox or volspeed to their gen 4 Bosch with 625 battery, how has it affected the range you can do?
Mines been detected twice now and gone into limp mode...I believe next time is permanent so I'm taking speedbox off .... Good whilst it worked but I don't want to trash a 3k bike....performance line CX gen 4 with smart drive
This is pretty simple really and it has been said many times. If you want to derestrict, get a Speedfun Furious EVO and delete the flow app. It’s not needed. Your bike will not be detected. My friend has had his on 2 bikes and over 3k miles without issues. It was even updated at the dealer with the Speedfun attached and again, there were no issues.
