You might struggle, I tried a few service/dealers & was told not available separately.Hi,
Looking for the part number of left and right motor mount brackets for my Rail.
The local dealer is moving slow on finding the part number.
The bolts worked loose & damaged plate tightened & was good for 5 months came loose again last week, happens again will have to reluctantly take to bike shop for warranty (motor?)
You'll be getting a new motor, I'm assuming it's under warrantyThanks, right know the bicycle is at the dealer. One mount is broke and one of the screw cannot be removed because the nut is spinning. They are working on that.
I will update as soon new information is provided by the dealer.
As you mentioned the brackets are not sold separately. Warranty will cover and a new motor will be installed.
I need the bolts prat number that hold those plates on or at least the size pitch etc. two of mine sheared right off I just discovered.
