• Warning!!
    UK Pedelec Law
    Worldwide Laws
Anyone derestricted the new Shimano EP8 yet?
Darren66
uk
Sorry, thought I'd be the first to get in there...:)
Does anyone know if Shimano ep8 have any anti tuning hardware or software, like Bosch gen 4 motor??
Check that your circumference is set correctly, mine was factory set at 2360mm and the actual circumference of the tyre l measured at 2250mm
l changed it to the actual value and the speedometer is now within 1km of Strava on a 40km ride.
I've got it derestricted with stunlocker. Just have it at 32kmh at the moment. I haven't tried the circumference tuning yet as I like having an "accurate" speedometer.
For accuracy on my previous bike i aactually lowered the circumference by about 9% to give correct odometer, in turn you also get 9% more speed
That's exactly what l did, although l got about 5% more speed as mine wasn't so far out.
l could probably have adjusted that in the Shimano app as it has a setting for a +/- 5% speed adjustment
Every little helps !!
What about Stunlocker, the guy says he's now updated his own software so you don't need to do a motor software downgrade in order to get it to work.
It probably isn't accurate now - mine isn't.
That shitty adjustment in the shimano app only changes the speed displayed. It doesn't effect distance recorded or actual assistance speed or anything else of any use.
My wheel circumference was 10cm out, it was (as always) set too large.
l adjusted it to the correct value using Stunlocker.
Now, the bike speedometer is within 0.5 miles of my GPS on a 20 mile ride.
Yesterday's ride was according to Strava 21 miles and according to the bike 21.4 miles.
Before l adjusted it, the bike would tell me l had done 22 miles on this ride.
lt's not a big difference, but it's nice to get it more accurate.
And l guess the bike will be a little bit faster too, not that you'd notice such a small difference!
But l've paid for 15.5 mph and l want 15.5mph, not 14.9
I tried ST Unlocker but my EP8 firmware isn't supported apparently
Did you get it to work? I just downloaded the App and it won’t connect to my bike…wondering if it’s because the EP8 firmware (bike shop updated it w/o me knowing 🤦🏻) is most recent version
You do realise tho that you might have blown your warranty with doing this as I did the same and was told that it voided the warranty. Only hearsay but just something to think about and maybe checkout before doing it.
Yes l realise that could be the case. Although l've only set it to the correct circumference and not a false setting to trick the ECU into making the bike faster.
    672K
