Rise motor error code
Steve G H
222
166
Sleaford
Messing with the etube app today and found an error code has been logged for my motor , see pic . Wondered if anyone had this before ? Bike seems to be working fine .
mark.ai
828
594
Windermere
Interesting ... wonder if the speed sensor missed the magnet briefly? Can't think what other sensors there might be. Guess there has to be a cadence and power sensor too somewhere.
Steve G H
222
166
Sleaford
Like you say there will be a cadence and a torque sensor at least , it's the fact it says in the drive unit . Best ring the shop and see what they say , if I can use a more local Shimano centre it would be more convenient
jim0905
194
117
West Yorkshire
Just had a look on my etube app and I have the exact same error. I went in the garage to update the firmware and I'm having real trouble with that as well. Got to about 20% and it failed, now the app is just stuck on overwriting the firmware which eventually fails
Steve G H
222
166
Sleaford
Funny you should say that because I updated the firmware on Sunday and it took ages , seemed to stop , said it lost connection then reconnected and continued by itself. I'd not even looked at error codes at that time , noticed that yesterday
jim0905
194
117
West Yorkshire
Kept saying the wifi was unstable and and failed acouple of times so I sacked it off and brought the bike in the house to try again which is when my problems started
chrismechmaster
811
419
Newbury
Wonder how many more of us have this same error and if it’s anything to really worry about
Steve G H
222
166
Sleaford
That's exactly what mine said , was unstable connection so I moved the bike closer to the house and it continued
jim0905
194
117
West Yorkshire
This where I could've messed it up. Think I disconnected or turned the bike off midway through before bringing it in to the hose to try again. It's now just stuck on a constant loop of the above screenshots
chrismechmaster
811
419
Newbury
Hi no not tried it yet just logged on to see if I had the same error code
So my fault was there before as haven’t done the firmware update
Have either of you guys Managed to get the firmware to update yet ?
RickBullotta
1,785
1,523
I had no issues with the firmware update, but I use the Windows based software and the SM-PCE02 USB -> eTube adapter.
RickBullotta
1,785
1,523
Also, if you turn the bike on and off with a foot on the pedals, you can get errors like this.
mark.ai
828
594
Windermere
RickBullotta
1,785
1,523
Steve G H
222
166
Sleaford
If it can log an error if cranks move as it's switched on its highly likely that's what's happened , especially given the position of the on off switch
RickBullotta
1,785
1,523
The torque sensor can't have any significant load on it during bootup which is probably when it does a calibration/zeroing.
chrismechmaster
811
419
Newbury
I agree totally
Also thinks like lubricating the chain I do my with the bike off , I I guess this could be another reason for the error coming up ??
Steve G H
222
166
Sleaford
Wouldn't have any load on it , be more a case of move crank out of the way as switch is pressed possibly
526K
