Dropper post
JC1982
South Wales
Hi all
Once I get my bike back from the motor replacement. I am contemplating changing the dipper to the fox transfer kashima and before anyone says. I am going with the factory to match the forks and shocks. Lol
The main reason for it though is the stock post and leaver even more, I really don't rate and have had to fiddle with the leaver countless times to try get sorted. Is the travel 150mm on a large. I can't find anything but the diameter on the net.
Thank you.
As an FYI the Transfer usually comes as post only and you have to buy a remote separately, IMO the Fox lever isn't that great, and a PNW Loam Lever or Wolftooth ReMote are much better.
Just changing the lever on most droppers for a good one will significantly improve the performance.
You existing dropper should have the size marked on it?
The problem I got is I don't have the bike. Its still in the shop I am not sure how long for either.
I was hoping to try and order some thing ready for it to come back.
Thanks you for replying, I will have a look at those remotes.
Which model Haibike is it
Haibike Components, Dropper-Post Remote 31.6, Aluminium, Telescope
Lol that would of helped. It's the all Mtn 7 large. I am assuming it's 150mm but can't remember.
If you are considering a new dropper then I can 100% recommend the wireless AXS system. Massively superior in almost every way. It's really a completely different experience using it and cleans up the cables on the bike too.
Thank you I will have a look, what's the batery life and cost on the like though.
Its not cheap, but there are some quite good offers available. Battery life is massive, about 60 riding hours but depends how much you use it. Just so much better than anything else out there.
I just put the AXS Reverb on my Full Fat Six to get rid of that crappy stock dropper and the cables and it is quite awesome! Pricey but awesome!
    670K
