Kenevo Gen1 2019 Kenevo 2.8 to 2.6 tire bottom bracket height
bhudzallmighty
Socal
My rear tire went kaput on my last ride. Thinking of switching to maxxis dhf/dhr 2.6 profile but concerned about the bottom bracket height
After 2.8's I went ewilds 2.6 front, 2.8 rear as a test. Felt good. Wished I'd gone 2.6 both ends.
Now on 2.4 DH22's. Love these. Probably a bit heavy for most people but the bike feels nimble.
No problems on the BB. I catch it occasionally, but only from crap riding and technique failures ! I do run shorter cranks though (but always have - it didn't need them, I'd already bought them so put them on anyway).
On stock roval rims? How about 2.5s? Not too skinny on 38mm rims?
Yup ! On stock rims !!!! It gives you more air volume. You probably loose out a little on lateral suspension when you're leaned over as the tyre can't flex as much as it would on a thinner rim, so you might notice this is you're a good rider.
2.5's are probably the ideal size I guess .. For me, 2.4-2.6 seems good.
@bhudzallmighty
Take a look at this tyre/rim chart from WTB
Page past the first chart to the chart for mtb
Thank you!
@bhudzallmighty
Thank you!
What year Kenovo you have? Because mine has Roval's 28mm internal wide (2020 Comp)
2019
I'm running a 2.6 Eddy Current on the back and a 2.8 Eddy Current up front on mine. BB height doesn't seem to be too bad but I have upped the front to 200mm travel.
The rear wheel is a stock Roval 30mm.
Hope this helps ?
    670K
