Any recommendations on a home bike stand for my e-mtn bike.
Which one did you get? This one at Halfords has a weight limit of 15kg, so I wouldn’t have thought is strong enough
I use this Yakima one, got it from Amazon (out of stock atm), it says 20kg limit, but works fine on my Levo which is just under 23kg. I've even used it to hang the bike from a bike rack to get the bike to lbs and back (with battery removed):
I use this Yakima one, got it from Amazon (out of stock atm), it says 20kg limit, but works fine on my Levo which is just under 23kg. I've even used it to hang the bike from a bike rack to get the bike to lbs and back:
I chose this one (I am in Canada so not sure what is available over the pond) - a few comments saying it handles the weight ok. I typically remove the battery when I put mine in the stand just to lighten it a bit. I'll let you know how it works as it should arrive tomorrow.
Just an update on this. - works great and holds the bike securely. I like it way better than clamping to the seatpost. Just make sure at the handlebars that no cables are underneath the crossbar. P.S. Ignore the messy garage ;)
    676K
