Motor Guard question
Bamba
Ca
Hello Decoy community, quick question/s on the motor guard:
1. torque spec on the 4 little screws that mount it?
2. the foam insert that comes with it was mounted on the left hand side (non drive) of the guard but it looks to me that it needs to mount in the middle of the guard and cover the water hole that is in the middle back side of the guard?
3. the foam insert of the guard has one side with a taller lip - should the taller lip be facing the front or back of the bike?
apologies in advance if this was already covered somewhere else. searched high and low and couldn't find it. Thanks.
My guesses from looking at the parts exploded diagram:
1) M5 screw...so maybe 3Nm? would see how much it compresses the guard.
2) drawing shows it in the center (via vert line in drawing)
3) Looks like tall foam part in front.
Thanks for your feedback. Most stock photos for some reason have the foam installed on the drive side it seems.(see attached non stock photo here but same deal. it seems to be on right side) I wonder if it shifts over time. Where is the one on your bike located? where can i find the diagram you are referring to? Thanks.
What model Rockguardz are you using here ? Fits good
Update: Never mind .. found it on their website (y)
    Join 43,166
