I used Gorilla tape on my wheel rims, as recommended by my LBS. It's great, looks fantastic and it works a treat.
But Oh boy! When you want to remove it what an absolute sod! When you peel it off the thick sticky adhesive is left behind. I have tried a proprietary "Sticky Stuff Remover" that has shifted all other adhesive residues before today, but not this time. I have tried iso-propyl alcohol which easily shifted sun-baked pine sap from my car roof, also a fail. It won't even rub off with a rough towel!
I contacted the Gorilla Tape manufacturers, hoping they might say use meths or soap & water, anything! To my dismay, I was told that they do not have a recommended method of removing the adhesive residue. The person I was talking to says that she has heard recommendations of using the tape itself to pull off the residue. That might work, as I have used Sellotape to do that on Sellotape residue. But it didn't..., well, maybe just a little bit. It does pull some off, but only reduces the thickness of the adhesive it wont pull it of the alloy rim.
I have tried picking it off, but it very, very, very slow indeed. I have taken a break from the task right now, so I thought I'd post here.
Does anyone have any solutions for this task? PLEASE!
I have at the back of my mind to try a hairdryer to maybe soften the glue and just rub it off. Or maybe hot water would be quicker?
