Trigger shifter clamps...
UVRail
London
Hi all,
quick question.. just looking at using a BBB BSP-90 for a SRAM GX Shifter. I don’t need all the Matchmaker gubbins, just a simple low cost clamp which can open up to fit on the bar without removing grips etc. Would the BBB work?
cheers,
UV
Nope. That's for fitting a front mech to a seat tube.
Think you need this...
Or buy another GX shifter cheap on eBay that comes with the bar clamp?
SRAM-Shifter-Clamp-Kit-for-XX1-X01-XX-X0-X9-X7-Trigger-Shifters-black-universal-26791-90160-1...jpeg
Thanks, yes, the SRAM is the clamp that is best suited - the problem is that my grips are a nightmare to remove, so I was hoping to find a clamp that would open up so I can fit it over the bar without all the aggro! Any ideas?
cheers,
UV
Used strong grip-glue then? Not aware of any other 3rd-party MMX solutions with a fully opening clamp, sorry!
Went for a Wolf Tooth shiftmount in the end to attach the shifter to my Shimano brake clamp.
The cost made my eyes water a bit, but an added benefit sill be a slightly tidier cockpit.
Seems a bit crazy that the dropper and brakes all have clamps which will open, as did my old SX shifter, but the mid/higher end shifters don’t!
cheers,
UV
    675K
