Ah... We have that kind of thing too...
We call it XC/hike-a-bike (for obvious reasons)
In regards to motors, now have 2500 miles on my Decoy and am starting to feel play in drive side crank, thought it was pedal spindle but unfortunately is motor. For those of you that have replaced an E8000, at what point (i.e. how much lateral play) do you think a bike shop/shimano service center will need to warranty? In other words how bad does it have to get to be a no-brainer replacement?
What I'm seeing is minor, maybe 3ish mm of play but I'm sure it's going to get worse fast I'm sure.
Has anyone purchased a reserve E8000 motor to have on hand? So often with my riding a spare of something is necessary to eliminate down time....like rear shocks.
Not seeing any online, where are you located? Any idea what the issue is? I see E7000's available on open market but nothing available in E8000.
I'm going to try and call Shimano, not sure if I'll have any luck. Called a couple dealers in my area (DC), no one seems to know about stock of motors unless they call someone.
UPDATE: YT called Shimano and they’re sending me a new motor. They said up to 2mm play is normal but more is not.
2mm of play is not what I would call 'normal'! If you can feel any play that shows it's due for replacement soon. I am an ex. precision engineer/engine tuner so used to tight tolerances, but even so, 2mm it is way OTT.![]()
I agree that 2mm is not normal so I made sure to tell them it was more than 2mm!
At least it wasn't too much of a hassle getting the motor approved. Hopefully the
new one will last much longer!
Bearings are manufactured with tolerances in microns (1000th of 1mm) so to have 2mm of play means it's been scrap for ages. I just cannot believe that a Japanese company would say that. 0.2mm would be OK but the more play there is, promotes even more wear.
This is putting me off getting another emtb with a Shimano E8000 motor. Will it's successor be better?
As a Turbine Engineer myself I would agree however the design looks like the
cranks are held by the two bearings so some play would be acceptable. To
there credit they are replacing my motor with no hassle so obviously they do
not think it's normal either. When I get the new motor I will check what the play
is and see if there is any right from the start.
Actually the tolerance can go down to .0127mm on a large turbine in relation to the bearings. Vibration is the killer for rotating engines and the more play in the bearings the more vibration.If you work on turbines (which are very large?), the tolerances will be greater as they need to be on bigger diameters. So 2mm of play on a 4m turbine is hardly noticeable. But 2mm on a 50mm bearing (if that's the Shimano main bearing size?) is shocking.
As you're going to be getting a new motor there shouldn't be ANY play whatsoever. If I got a new motor and there was any play in the main shaft, I would just send it back.
I am still considering getting another emtb with an E8000 motor as I had no problems with mine although I only used it for about 950 miles/1529km.
I would have liked the Shimano app to have more features like the Specialized Mission Control app but it was OK although I did have to buy an iPhone to use it as it wouldn't work with my Android mobile.
Would be really cool if EP8 could be used as a replacement for the E8000... As for E8000 - did anyone see it sold separately?
My battery still says 40 miles on ECO (medium) and it's a 2018 with almost 4000 miles now and 400,000+ feet of climbing. But because I wanted it to last as long as possible I made a 250 wH DIY range extender that I use for the first 12-15 miles of every ride.I'm at 3400km/2100 miles on my original E8000, and it's going strong. Batteries, not so much...
I had mine replaced at 1700ks, the replacement is currently at 4400ks and I've got about 10 months warranty left if you go on the two years from original purchase date.
That's beautiful. I have a thing for ridge climbs and that looks like an amazing line.
No idea sorry - was picture commenting on @Gary about 'All Mountain'. I too have no idea what it means, but would expect to be able to climb K2 or Everest if it says All Mountain.That's beautiful. I have a thing for ridge climbs and that looks like an amazing line.
Where is it?
Do you have any more details on how you made the range extender?My battery still says 40 miles on ECO (medium) and it's a 2018 with almost 4000 miles now and 400,000+ feet of climbing. But because I wanted it to last as long as possible I made a 250 wH DIY range extender that I use for the first 12-15 miles of every ride.
There is a thread in the Focus section and I'm still working on the final version. It's just a 20 cell hoverboard battery that gets plugged into a Rosenberger cable/connector. The Focus Jam2 senses the battery when plugged in and uses it until it's unplugged or depleted. All the other work is about packaging. My latest will be a 3.6" diameter "bottle" in an oversize waterbottle cage with a charge level meter. Waiting on a friend to make the final version of the bottle. The hoverboard batteries are inexpensive but the one I've settled on uses 3500mah Sanyo/Panasonic cells and cost a bit more than the cheap Chinese batteries. It's also just a bit slimmer so I can keep the already large bottle size down to a minimum. The one I'm currently using was built in the US and cost $129. I think there are similar ones on aliexpress for around $31. I just don't know if these are very good but this one look to be a very compact build size. US $23.68 36% OFF|36V 7ah 6Ah 4.4Ah 5.2Ah high drain 2 wheel electric scooter self balancing lithium battery pack for Self balancing Fits 6.5Do you have any more details on how you made the range extender?
