Decathlon STILUS Full Suspension Electric Mountain Bike - SRAM SX
And this is the original witch is off set a few mm
It’s the Bosch spider he is using I’ve got the same issue but making a spacer up
Just googled that part number - it's non-Boost. Do they do a Boost one? FSA do I think.
chain line : Standard chain line (non Boost), optimized for Bosch BDU4XX drives
I’ve added 3mm space to the chainring and that’s the clearance on the rear tyre 2.8 wide
I’m making a spacer to fit on the shaft of the motor and remove the 3mm spacers on the chainring hopefully that will work
What's the difference between boost and normal
Your front and rear hubs are wider (110mm and 148mm). Consequently, the drivetrain is shifted outwards, which means your chainring should also sit further out. My understanding, anyway ? Non-boost is 100mm front and 142mm rear. So you either need Boost components, or will need to adjust with spacers.
Yes all straight. Original chainring had a bigger offset which brought it further out than this one
Hi, notice you have the same Bosch spider as me, which is the normal chain line of 50mm we both need the boost version that gives us 53mm,only stock I can find is in Italy ?
Not sure where it’s coming from was €43 in all bud
Worked out £44 from Italy, probably be a week or two delivery, bike rides fine so not a problem waiting I don’t think..be interesting to see how much extra gap I get from tyre to chain and if it shifts smoother because it’s pretty good anyway.
I’m only getting it so I can use my own chainring can swap out easy then
    676K
